Old 02-21-2006, 09:36 AM
Default Brake reservoir heat shield
Since I noticed the Brake master cylinder getting very hot, I made a heat shield for the brake and clutch reservoir’s. I used some motorcycle heat shield designed for farings (the thick stuff in the below pic), and some cheaper normal silver-foil style shield.
I used a flat plate (cut out of an old computer case) that mounts to the side vent, and has a bracket that mounts round the brake reservoir with a U clamp that I bent out of an old piece of steel, and a small box section that mounts between the reservoir and plate, so the plate can by held tight by the clamp, but still a space between the plate and reservoir. Then sprayed it all black.
I hope the rest of the pic’s are self explanatory
Old 02-21-2006, 02:22 PM
Cashburn's Avatar
Backdraft Racing Dealer
Shaun works for us ... though like myself he only gets celebrity status out of the relationship
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 02-24-2006, 04:59 AM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
I never noticed just how hot the master cylinder gets, but will check that out soon as weather breaks. Nice job.
I also saw a post about the LED brakes. Can you fill us in on that one?
Tis better to burn out than to fade away. So "Lite 'Em Up!"
Old 02-24-2006, 05:35 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Shaun,
Nice work. Excellent design and fabrication. Mabybe one suggestion. Round the corners on the engine side of the plate. It might save ripping a wrist or hand open on the corner.
You should make up a few of these and sell them. I would buy one if you don't price them too outrageously.
Skip B
Old 02-24-2006, 05:39 PM
Cobra Make, Engine: Backdraft 302
feel like making another? I'll buy it.
-- Ray D
Old 02-25-2006, 04:46 AM
Dinobyte's Avatar
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
If your headers were ceramic coated, would you still have the same heat problem?
Also, what about using header tape?
Old 02-25-2006, 05:18 AM
Tommy's Avatar
That was a nice piece of work. But those considering their own heat shield should know that most of the heat from the headers is radiant and can be blocked with something as simple as a thin sheet of aluminum as long as there is an air gap between the shield and the item being protected.
Tommy
Previously owned EM Cobra
Old 02-27-2006, 04:34 PM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
I have ceramic coated headers and wraped them with header wrap. It is still to hot, and I cook my brake master cylinder fluid. I seem to have the most trouble when the car sits idleing, without air flow. Jay's shield should work well. I would also be interested in one should they go into production.
JayB
Jupiter, FL
Old 02-28-2006, 04:14 PM
jeffko's Avatar
Jaybar, I would get that header tape off your pipes. I believe you will ruin the ceramic coating.
I am considering making a stainless steel shroud that would maybe match the surrounding engine compartment. Since it is radiant heat you just need to deflect it. Maintaining an adequate air space where air can move through the space is the most important.
