Old 03-29-2006, 03:33 AM
letitbe's Avatar
Cobra Make, Engine: Backdraft #202, Ford Racing 342 Stroker 400 HP
Send a message via Skype™ to letitbe
Question BDR clutch adjustment
Has anyone needed to adjust their clutch on their BDR?
What is the proper proceedure?
Trans. T5 WC
Clutch King Cobra
Letitbe
Backdraft #202
Old 03-29-2006, 06:35 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Trans. T5 WC
Clutch King Cobra
Could you be more specific?
If you are talking about engagement point, the shaft between the clutch pedal arm and the clutch master cylinder is threaded and will allow some adjustment there. Also make sure the master cylinder is properly filled. That's the extent of my knowledge on the subject....
Old 03-29-2006, 02:37 PM
Cobra Make, Engine: backdraft racing 302 ford
Smile
If your clutch needs ajustment make sure master cyclinder is full first, bleed if need be. Make sure ajustment on clutch peddel in car is set and tight and lock nut is set they can come lose.The clutch rod on slave cyclinder has ajustment thread to set engagement, make sure the boot on rod is in good shape!!! or cyclinder will not last long ,do to dirt.
If it is just using a threaded rod. weld a washer on it to hold boot in place or the boot will tear.
Good luck ED
Ed
