Old 05-01-2006, 01:30 PM
chuckmynatt's Avatar
Cobra Make, Engine: BDR / 347 stroker
Default Looking for electrical schematic
Does anyone have a schematic for a Backdraft that they could email me or post. I've got a few electrical "queerons" that I'd like to sort out.
Chuck
"It just goes to show ya, no matter where your at, there ya are"
Old 05-01-2006, 02:09 PM
Cobra Make, Engine: backdraft racing 302 ford
I also would like a schematic for a Backdraft , trying to fine the wire for the windshield washer
ED
Ed
Old 05-01-2006, 02:13 PM
Cobra Make, Engine: Cobra-less
Chuck, the factory (not Reg) should be able to e-you a copy of the schematic for your car. I have a crude one for my car, #128. If your build number is close, e-me and I will send it to you.
Al
albie@inreach.com
Cobras Gone But Not Forgotten
Old 05-02-2006, 07:38 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
I could use one for car #38. I'm having charging problems.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 05-02-2006, 09:07 PM
Al,
I got it. Perfect! Thanks alot.
Chuck
Old 05-03-2006, 06:57 AM
Thunder1, private e-me.
AL
Old 05-04-2006, 09:01 PM
Cobra Make, Engine: BDR 195, 351W
Thanks for the copy, Al!
Bob
Old 05-05-2006, 07:30 AM
Cobra Make, Engine: 1965 Backdraft #58, 347 Stroker
Send a message via AIM to Cobracraig
Trueoo7,
I have a copy of a schematic for BDR #058. I imagine it is pretty close to yours if you still need it. If so, email me at toeyotacraig@cox.net. I can scan it and email it if you need. Have a good one.
Cobracraig
"Drive it Like you Hate it!"
Old 05-05-2006, 12:14 PM
By the way, this is my problem:
Here are the symptoms
1. Engine tends to get hot in stop & go traffic especially at night.
A. Constant cruising speed - temp is ok.
B. System voltage with fans off is about 14 volts.
C. Turn fans on (day) - 13 volts initially but will drop another 1/2 volt with lots of stop & go.
D. Lights on, fans on - 11.5-12 volts over time in stop & go.
E. Light switch body gets prett warm with lights on.
F. Some wires under dash get pretty warm, especially in the white plastic connector near ignition switch.
I've already swapped in a 100 Amp alternator, checked all grounds I could find, checked battery terminals. When the system is reading around 12 volts on the dash I have put a digital meter on the battery and found approx 13 volts there.
Has anyone else had a similar problem?
Chuck
