Old 05-16-2006, 02:03 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Default Strange noise in my BDR
The other night I started hearing a strange noise comming from the engine area. It was only at a certain point as I was going to shift. It sounded like either the header springs were viberating or a supercharger when you decelerate. After doing some looking around I finally found the problem. It was a vacuum leak at the vacuum port gromet on the power brake booster. It seems that only at a certain point the engine viberation or movement would allow the leak to occur. I guess I'm going to get some black silicone and make a small bead around the gromet where the plastic fitting goes into the booster unless someone has a better idea. I also found that's why my idle speed has been somewhat erratic.
Just thought I would let you'll know.
David
Old 05-17-2006, 03:04 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Thanks David, its posts like that, that make us all a better mechanic. I'll keep an eye out for it.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 05-17-2006, 03:06 PM
go to hi-lo or autozone and look in their help section. You can find a new seal, i forget it is similar to a pvc valve grommet or maybe the rubber things you use to protect wires when they go throught the firewall so they do not get cut.
Old 05-18-2006, 09:49 AM
Does the plastic fitting that goes through the bushing into the brake booster (the one that connects to the vacuum line) just pull out?? Is there any special tricks or words of advice before I try to remove the gromet?
Thanks
David
On a bad day life is good. On a good day life is great. Enjoy life!
Old 05-18-2006, 10:19 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Yes, it should just pull out ( well, at least they have for the past 30 years ).
May I suggest a bead of silicon grease for the seal leak if it is small and the grommet appears to be the right one.
Old 05-18-2006, 11:18 AM
I feel the gromet is the correct one since it came on the car from Backdraft, but it almost seems like it may have shrunk or something because where the plastic fitting( I think it is a check valve) goes into the gromet it is fairly loose. If you move the hose at all you can hear the sucking noise.
David
Old 05-18-2006, 11:24 AM
you will probably rip the grommet when removing the plastic piece since it has a big lip on the inside, that is how my was damaged
