Old 08-13-2006, 03:52 PM
Cobra Make, Engine: backdraft racing 302 ford
Default Accessory outlet
accessory outlet
I have a open 15-amp fuse , is this large enough for a accessory outlet.
from the pic it's right under the clock fuse. anyone with owner manual that shows the wiring.
Thank in you advance ED
Ed
Old 08-13-2006, 04:40 PM
ROUSHAC's Avatar
Ed,
Hope this helps.
Cheers!
Dave
Dave
Old 08-22-2006, 04:29 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
thunder1
According to the diagram, it looks like there is a "spare battery" fuse above the choke fuse, which is right above the clock fuse. This should work if it is not being used. 15 amps should run most accessories I can think of. What are your going to put on it?
Also, your heat shield is working well on my car. No more spongy pedal after long runs. Now, I am interested in your rock shield I see in your pictures. Are you going to make some of these up for other guys? If so, I want one. In addition, I would like a smaller one for the bottom/oil cooler opening. Let me know what is happening with this. If you aren't going to make them up, then perhaps you could let me know a source/brand/specs on the metal mesh you used.
SkipB
Old 08-22-2006, 05:13 PM
Hi Skip
Glad the heat shield works for you, I have more made up if anyone else wants one.
Your right about the "spare battery" fuse works great to run a fan for the hot days here in Florida, thanks
The rock shield is made out of SS woven wire the same as the jaguar cars use, I hope to be making them for the cobras.
I am still working on my design so the installing is easy. In order to get started I would need to order enough material for six cars.
Please give me a call 321-276-4167
Thanks, ED
Ed
Old 08-22-2006, 05:30 PM
Ed,
Well, you can count on me for the first rock shield. I like the idea of stainless steel. Can you make one for the bottom opening as well. A lot of cars have oil coolers and will need it. Unless you have one screen that will cover both. I will have to go out to the garage and see if that is even possible!
So come on other BD owners, pony up and order, so Ed can make the rock shields.
Skip B
Old 08-22-2006, 06:41 PM
Cashburn's Avatar
Backdraft Racing Dealer
Ed,
Give us an idea on price. We could probably grab 2 of them to get things going.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
