| 29 |
11-02-2006, 06:48 PM
tx
Cobra Make, Engine: BDR 323 392
break-in
i bought BDR 323 with 800 miles/// have 1200 now and wondering if the is any breakin maintenance for the car
11-02-2006, 07:09 PM
Backdraft Racing Dealer
The factory recommended maintenance is at the following intervals:
- First Drive
- 100 Miles
- 500 Miles
Outlined in your Owner's Manual. Since you bought it used I would do the 500 mile checklist and then you should be good to go.
11-03-2006, 04:15 AM
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
I would change the oil, non systhinic at this point (wait till you have 3-4,000miles on it for sythinic).
Then take it out and wind the P*ss out of it!
JayB
Jupiter, FL
11-03-2006, 08:04 AM
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Jay:
I don't see a factory recommended schedule for maintenance in my BDR's Owner's Manual (#168).
Is this something you can post here for all to see?
Thx!
11-03-2006, 08:16 AM
I can email you a copy later if someone does not beat me to it.
11-03-2006, 08:42 AM
Fantastic!
wsteelhamm@aol.com
Thanks!!
11-03-2006, 09:22 AM
nj
Cobra Make, Engine: BDR #188 342R Roush
Break in ?
Jay,
My manual never had break-in in it.
I just figured if I beat every import and Mustang it's ready..........
Please email me also.
thanks
tom
#188
rocket71@comcast.net
 No I wouldn't race you, my lug nuts require more tourqe than that thing puts out........
11-03-2006, 11:18 AM
Ill
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Break in is over. Keep your oil changed with a straight 30wt.
Rings don't need the breakin like they used to. Instead of hard pulls and backing of they just recommend moderate driving for 500 miles. The critical breakin is the camshaft. FYI With plenty of moly on the lobes and a primed oil system you idle the car to operating temp looking for leaks and obvious noises. Bump the idle to 1800 rpm and let it run for 10-15 minutes. Even a fresh dragstrip engine will get a cam breakin before running.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
11-03-2006, 02:45 PM
Cobra Make, Engine: Backdraft Racing BDR144
Cashburn,
I would like a copy too!
email sent
Wayne W.
Pewter with Steel Gray Stripes
11-04-2006, 05:40 PM
Cobra Make, Engine: Cobra-less
I would like one if it has to do with chassis things. I did oil changes at 500, 1000 and 2500. Switched to Mobil One at 2500.
Hey Wayne, How are things?
AL
Cobras Gone But Not Forgotten
11-06-2006, 05:45 AM
tx
cashburn
can you also send me anything you have for breakin..i sent the guys at backdraft an email last week and havent heard back yet...if it isnt a problem, please email a copy or link
11-06-2006, 01:44 PM
timhorr,
You should be talking to your engine builder. Or Ford Motor Company if it is a crate enging.
JayB
Jupiter, FL
11-06-2006, 03:51 PM
Jay,
Thanks for the manual, it is different from the one that I got with #144. I found that the wiring diagram did not copy well. But, I found the clear copy of it in your gallery.
Al,
Doing great here! How about you? Going to WSCB 07? I am planning on it.
Wayne W.
11-06-2006, 04:45 PM
tx
breakin
Jaybar...Reg put in the engine
