February 2026
Old 01-25-2007, 12:56 AM
Rwillia4's Avatar
Default Keith Craft 427W FI
The engine has arrived. I was only able to unpack it once the wife went to bed, hence the dark picture. The FedEx slip said it weights 750 pounds!!! Yeah that includes the shipping box, flywheel, pressure plate, clutch, fuel pump, wiring harness, starter, and EFI stuff...but 750 lbs!! I'm goingot have to put it on a scale to find out but I was thinking under 500lbs. And no the FedEx guy was not happy having to push it up the driveway.
T-56 is also here. What type of tranny mount works best for the BDR a 2 bolt of 4 bolt?
Weather in San Diego today was low 70's so the sooner it is together...let the drive'n begin.
what is the trick to getting a good picture attached? the little one attached sucks
Old 01-25-2007, 06:30 AM
Blittleton's Avatar
CC Member / Sponsor
Rwillia4,
You need to upload the picture to your gallery. Once it is there you can copy the link to the clip board, then paste the img to your post. It really seems complicated until you do it once or twice.
Nice looking motor, we have a 427IR coming in from Roush today or sometime this week. Have you installed these before? The wiring harness isn't too hard to figure out but take your time to do it right. I usually cut the hole behind the motor but far up enough so you don't see the harness for the inside of the cockpit. Good luck and the motor looks great.
Bill
www.gcperf.com
Old 01-25-2007, 10:35 AM
Rwillia4's Avatar
Thanks Bill,
This will be my first time doing an install... as I would prefer to learn from others any advice will be helpful.
Here are some better pictures. I don't have the dyno sheets yet but was told over the phone it hit 606HP and 587#Trq.
http://www.clubcobra.com/photopost/s...8&limit=recent
http://www.clubcobra.com/photopost/s...7&limit=recent
http://www.clubcobra.com/photopost/s...9&limit=recent
Old 01-25-2007, 11:26 AM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
I would love to see the spec's on your KC motor. It looks awesome.
To my Cobra: - - when I'm with you - Oboy!
Old 01-25-2007, 12:28 PM
Rwillia4's Avatar
So would I...still waiting for the paperwork in the mail!! What did KC do for you? AFR 205 heads? I have the 225's b/c he was "out" of the 205's. I could see this as the major difference. You have a substaintialy higher peak HP for the "same" engine. I wonder what the differences are? I asked for a streetable engine, I'm not sure if they made any changes (cam, timing,..). I'm itching to see the dyno slip to see if is is realitively flat over a large RPM range. ...snail-mail you gotta love it!
Old 01-25-2007, 12:56 PM
Poolw's Avatar
Rwillia4,
I got the 225 heads too. My cam if fairly wild, but it idles at 1100 and its happy running at anything over 1900 rpm. I was disappointed that the dyno sheet started at 5000 rpm. I would have liked to seen it start at 3000 rpm. My cam is a Comp Cam with a lift of 576 on both intake and exhaust. the duration is 252 intake and 262 exhaust. I'm not sure what all that means, but it sounds awesome. You can go to my web site "http://www.venoms1.com" , then go to spec's for detail on my motor and the last page is my dyno sheet. It will be interesting to do a comparison
poolw
Old 01-25-2007, 06:27 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Rwillia4,
Wow, great engine. I am also in San Diego and would love to see your car, even before you put the engine in it. Where are you located? Are you building it yourself? Just curious and anxious to meet another Backdraft guy. Have we met before?
SkipB
Old 01-25-2007, 09:41 PM
Cobra Make, Engine: Superformance #1048, 392w
where is their pricing for the 427fi? i can't seem to find it.
nathan
Old 01-26-2007, 12:38 AM
Rwillia4's Avatar
SkipB you have a PM
nblumberg- I called KC and asked for an engine to be "adjusted" from the 427ci package 2 to -carbs +TWM with FAST XFI control. He and Tony was very willing to do what I wanted, (it is all about money ). If you need more specifices let me know or give KC a call.
Old 01-26-2007, 12:42 AM
Rwillia4's Avatar
Poolw,
I'll have to go look at the cam box to see what is stuffed in there. Our engines seem the same except carb/FI change. I will post the dyno sheet when I get it.
Old 01-29-2007, 10:10 PM
Rwillia4's Avatar
Default Cam Specs
Here is the cam specs:
http://www.clubcobra.com/photopost/s...500&size=small
Old 01-30-2007, 10:47 AM
SP01715's Avatar
Very nice motor, Congrats....
Old 01-30-2007, 11:54 AM
xlr8or's Avatar
Rwillia4,
I am also in San Diego and would love to see the car. If you need any local help just holler. Another local car has a KC 514 with the TWM/FAST setup so if you need any help doing the final tune he can certainly help.
Old 01-30-2007, 11:17 PM
Rwillia4's Avatar
The Car is here and itching to have power and tranny installed
Good to hear that other with FI are in the area. I will probably need some help on figure'n out the FAST system.
I was hope'n to get it together before the first sunday of the month meeting at IKEA...not going to happen this month.
I did get some paperwork in the mail today
Old 02-05-2007, 11:31 PM
Rwillia4's Avatar
xlr8or,
I saw a big block with TWM/Fast in a blue Superformace on Sunday morning at IKEA. It had a big crack in the windsheild probably from the torque twisting the frame... Looked nice.
