Old 03-09-2007, 01:12 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Question Correct tire pressures for 15" BFG
I've searched for the "right" answer to this question and have seen several different recommended pressures. I am looking for what works well for you on your Backdraft for street driving with those "wonderful" 15" BFG Radial T/As.
I don't need input on 17" tires, ERAs, FFRs, racing pressures, etc.
Thanks,
SkipB
Old 03-09-2007, 01:16 PM
Cobra Make, Engine: Venom 351W Mild Cam 600cm Holley MSD T-5
Send a message via AIM to Smoking Cobra
I run mine around 26 lbs. Much better ride and handling. Otherwise you feel every bump on the road.
joeg
Old 03-09-2007, 01:26 PM
Cobra Make, Engine: backdraft racing 302 ford
Hi Skip
I have 15" and i also run 26lbs the backdraft rides good but this does make for a nice ride.
ED
Ed
Old 03-09-2007, 02:12 PM
Rick Parker's Avatar
23-26 Will Get You Where You Want To Be.
Rick
Old 03-09-2007, 02:21 PM
Guys,
Thanks for the rapid replies. I assume you mean 26lbs both front and rear. I have seen a bunch of guys swear that the fronts must be higher. But, if 23-26 works all around, then fine. I will try it. But Rick, do you mean 23 front and 26 rear?
SkipB
