| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
05-23-2007, 11:53 AM
Ill
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
New BDR Half-shafts
I have heard a rumor that BDR is near perfecting their own IRS half-shaft. I have broken two of them so, if true, this would be a very welcomed upgrade. However, it makes me wonder what kind of strain would be put on the differential output shafts. I have broken one of those also.
I was also wondering if there is anyone that has changed the E36 IRS to something like an 8.8 IRS out of an SC Thunderbird or even a straight axel.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
05-23-2007, 12:16 PM
CC Member / Sponsor
Jeff,
They are in the process of making new shafts, they will be the equivalent of a M3 half shaft. It will have a bigger knuckle and is stronger. I can't remember if they are making a output shaft or not. I'll get back to you on this.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
05-23-2007, 01:31 PM
Club Cobra Member
IL
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Jeff,
I sent you an email via CC.
Lowell
05-23-2007, 10:05 PM
CA
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Jeff,
What type of driving are you doing?
05-25-2007, 08:54 AM
IL
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Originally Posted by Rwillia4
Jeff,
He is a member of the WCCC. We are bordering on the crazy... Drag racing and road racing. Jeff you going to Mid Ohio? I probably asked you this a million times but figured once more should be good.
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
05-25-2007, 09:33 PM
Ill
Rwillia4..drag racing is what is breaking the rear end.
Sid..I don't think I can get the extra time off work.
04-23-2012, 08:14 PM
Breaking stub axels on my jag IRS
I am breaking shafts drag racing as well. I have a Jag IRS with a 9" head so solved 1 problem and moved it to axels. Dose anyone know what material is best to make replacements stub axels from??
04-25-2012, 07:29 PM
MA
Cobra Make, Engine: Backdraft
I am glad to hear they are upgrading the halfshafts as I bust both of mine. BDR blamed it on the limited slip and hp of the engine (600 Hp). Thank god for Vintage as they stood behind it when BDR didn't. I upgraded to Driveshaft shop half shafts. I broke both (thankfully) of mine under full throttle in second gear which is not a worst case scenario in terms of torque applied.
04-25-2012, 09:13 PM
Stolen Avitar
GA
Guys, you do realize that this thread is 5 years old right? And the half shafts being discussed have been out for some time. DJ, if you're not on backdraft boys you may find more info there.
COB98, you posted a good, relevant question but did it in the BDR forum section where everyone is running BMW gear. If I were you, I'd go into a more relevant section and start my own thread to get a discussion started. I think you'll have better luck that way.
Cheers, Steve
04-29-2012, 04:28 AM
MA
Lovehamr- Just for the record I broke both of my halfshafts last summer on chassis 992 so it is still a relevant issue (at least to me). It was one of my biggest concerns when I bought the car. BDR had no answers or explanation to the problem, they could not even provide a torque rating for the half shaft they provide. Owners with higher horsepower shouldn't assume they may not have a problem. Braking halfshafts will make anyone pucker up!
04-29-2012, 09:34 AM
Yep halfshafts are an issue but the lesser of two evils. You could go with the driveshaft shops upgraded ones but then the problem may transfer to the dif. sect.
Remember these cars are based on BMW parts and not designed for the high HP and torque on the dragstrip.
I think BDR concentrates more towwards the road tracks for these cars than the short track 1/4 mile.
05-03-2012, 07:46 PM
CA
Originally Posted by mln385
... and not designed for the high HP and torque on the dragstrip...
I don't know mine seems to handle the HP rather well. The thing that keeps breaking on my is the tire-to-road contact.
05-04-2012, 05:59 AM
How do you launch at the dragstrip? Are you dragging the clutch through the beams? Do you have the LSD?
