Old 06-10-2007, 08:05 AM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default BDR drive shaft removal
How do you remove a BDR drive shaft? 302 with a T5 tranny.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 06-10-2007, 09:14 AM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
Unbolt it from the diff first. Then slide the drive shaft out of the trans. The rear of the drive shaft will need to go up on top of the diff to get all of the way out. It seems imposible but it will come out.
Remove the drive shaft safety loop first if you have one installed.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 06-10-2007, 05:22 PM
tamanaco's Avatar
Gatorac, Looking at it...it sure looks impossible. I'll give it a try. thanks!
Old 06-10-2007, 05:46 PM
Cobra Make, Engine: backdraft racing 302 ford
hear the link for the trans removel Dropping the trans
ED
Ed
Old 06-10-2007, 06:07 PM
tamanaco's Avatar
Thunder1...thanks
Old 06-10-2007, 08:39 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Make sure the tranny is in neutral when you are trying to stuff it up there. If not you might have a harder time
