Old 07-03-2007, 01:29 PM
FST FOX's Avatar
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Default Adjusting the E-Brake
I have an early BDR and the E-Brake needs to be adjusted and just wanted to get any helpful hints as how to do it before doing it, thanks in advance
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
Old 07-03-2007, 08:49 PM
Cobra Make, Engine: Venom 427, Ford Racing 392ci/430 hp
Default Adjusting the E Brake
FST FOX,
I have a Venom-identical to an early Backdraft?-anyway it has the same BMW suspension/breaks. According to the owners manual (I copied this)
“Remove one rear wheel nut from each rear wheel. Jack up the car. Turn the rear wheels until the nut openings are approximately 65 degrees to the rear of the top of the wheel. Located thru this opening should be a ratcheting star adjuster. Use a thin screwdriver to ratchet the adjuster. On the left side the adjuster needs to be ratcheted up, while on the right side it needs to be ratcheted down . Ratchet each side until the wheels cannot be turned. Once this is done loosen both the ratchets by 17 clicks. Both wheels should turn easily.
At the parking brake lever, remove the leather cover. Pull the lever up six ratchets. Tighten both cable nuts located on the lower front of the lever, until the brake just starts to bind the wheels. Once the lever is released the rear wheels should turn easily. Replace the wheel nuts (I bet they mean the cover) and lower the vehicle to the ground.”
I hope this helps, as I said I copied this verbatim from the Venom Owners Handbook.
Good luck
Rich
Old 07-03-2007, 08:51 PM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
FST FOX,
Try This,
http://www.bimmerdiy.com/diy/e36brakesystem
Step 29 is the E-Brake adjustment.
I have adjusted mine using this method and it works very well.
HTH
Wayne W.
Pewter with Steel Gray Stripes
