09-03-2007, 07:55 PM
Trunk mounted fuel pump
Has anyone mounted their electric fuel pump in the trunk, is it a good idea? I have a Barry Grant 220 and mounted it inbetween the diff and rear cross member. It was the only protected spot under the car it would fit. Gear oil leaked out of the weep hole on the diff, after some tight cornering and sprayed on the pump which fried it.
The diff was filled to the proper level with RedLine synthetic (I did it outside of the car on a level surface) so I don't think it was overfilled. Anybody else experincing leakage from their weep hole?
09-03-2007, 09:09 PM
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Oh dear god...do NOT mount the fuel pump IN the trunk!!!!!!!!
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
09-03-2007, 09:36 PM
az
WHY NOT?
double ugly
09-03-2007, 09:40 PM
ROFL...looks FABULOUS, seriously, looks really good, I just don't know if I want my luggage THAT close to the fuel pump...LOL
09-03-2007, 09:45 PM
Does TWA800 ring a bell? Fuel vapors form in closed spaces. Fuel vapors go boom.
09-04-2007, 06:40 AM
Beam Me Up Scottie
MA
Gas lines should never be run inside any car. Way to dangerous ... but any Cobra is dangerous by design
The BEST location for an electric fuel pump is below (or as low as possible) and behind the fuel tank. This way, gravity and your forward motion increases the "pressure" at the fuel pump inlet.
Warren
09-04-2007, 07:39 AM
a quality, good looking installation. I know of several racing applicaions where fuel lines, cells, and pumps are in far more dangerous locations. just for example, in many boats, engines and fuel pumps and lines, are all located in closed areas....there are no vapors from a closed system (unless there is a leak). there is no combustion source in a trunk. Externally mounted pumps are far more likely to leak or get damaged by the road than this application will. Great job my man!
09-05-2007, 04:06 AM
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
I'd have to disagree with this one. Boats are designed to venilate the fuel/motor areas. Also, our batteries are in the trunk. You're right...there are no vapors unless there is a leak...and there is no spark unless the battery cable comes loose. I'd keep the the pump outside.
Eric
09-05-2007, 05:48 AM
hmmmm,you know that's a real common scenario....a leaking fuel pump at the same time a battery cable comes loose....
if one thinks about every hypothetical thing that could go wrong in life, even extremely unlikely things...why bother getting out of bed in the morning.
09-05-2007, 05:51 AM
NJ
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
...and you NEED an electric fuel pump??????
...I know they look and sound cool, but why does everyone insist on using one? Do you REALLY NEED one?
I was going to install one in my 289 and then figured staying with a mechanical unit. These cars are dangerous enough already, if you get in an accident, the electric pump will keep on pumping fuel instead of shutting down the flow like a mechanical pump would.
JMHFO.
REMEMBER....In Case of Spin....Both Feet in!!!!!
09-04-2007, 08:53 AM
az
cbreez, thanks. I had Roger Bolick do the install before I picked the carbon car up. He does very good accurate work.
double ugly
09-04-2007, 07:06 PM
Yes, original Cobras...
09-05-2007, 05:56 AM
Not all of them did, just the handful of Race Cars (Comp and S/C) had the electrics.
...the rest of the fleet just ran with the mechanical pump.
09-04-2007, 07:26 PM
az
CSX 3020
double ugly
09-05-2007, 08:38 AM
ont
Cobra Make, Engine: Most likely D&D,302 stock for now
Personnaly i would mount the pump OUTSIDE any confine space and as low as possible so if it leaks the fumes would not get trapped and it would leak on the ground instead of running inside the trunk and seeping on electrical connections.
09-05-2007, 08:51 AM
Cobra Make, Engine: CSX4000 w/CSXblock
I have to agree w/using a mechanical pump VS the electric on the Backdraft. As mentioned earlier in the thread, there is a safety issue w/the electric pump running after an accident.
09-05-2007, 11:24 AM
I have to agree that a pump outside the trunk is way beter (MO).I ran a mechanical pump forever and never had any problems what so ever. In my wisdom I changed to an electric pump,mounted to the frame near the rear suspension,and every time I drive the car I worry about the high pressure in the line from the rear of the car and the fact that now I have another source of leaks to worry about on the engine, the pressure regulator. I will be taking the electric pump off and reinstalling the mechanical pump shortly.A much safer scenario all around.So much of the "Hot aftermarket Products" that a lot of us are duped into buying,like fancy ignitions etc, have absolutely no benefit at all other than bling,and of course adding more weight to your car.Simple ,light and reliable,thats my motto!!!
09-05-2007, 01:41 PM
a real matter of opinion if it's "safer" all around, a fuel pump could start a fire in the extremely hot engine compartment of a b/d quite easily in a crash....hypothetically of course!....many, many vehicles today in production run electric fuel pumps all day long, some even mounted right on the fuel tank!! How unsafe those millions of cars!
There are safeguards available like inertia shut off switches for those that feel the need for the extra protection...you also have that big switch between the seats and one on the dash...
Electric pumps and their regulated pressure are a great cure for vapor lock problems and have been used for years! I bought and used my first one in the early 70's. They aren't some new trick bling item...
To the poor guy that originally started this thread, the applications that were displayed sure look safe, and I would have no problem using something like that.
09-05-2007, 02:28 PM
I must agree that the installation looks top notch!!,
09-05-2007, 03:13 PM
ont
Can somebody tell me what i would need in extra parts to modify my fuel delivery system from electric to mechanic. I'm using a timing cover that was meant for EFI,no opening for mech. fuel pump. I heard that i would have to change my timing cover and ad an eccentric ( is it the small timing gear that has to be replaced as well,with one with a lob on it for the pump. I have an idea but i'm not 100 % sure. Cost wise which conversion is the cheapest ??
