1Likes
04-18-2008, 09:18 AM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Better Rear Shocks
Any one try out any other shocks for the rear of the car? I was wondering if the KYB shocks that they make for the VW would fit the same and work better. I'm just looking for a little better rebound when tracking the car.
Bests, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
04-30-2008, 10:18 PM
Well, I got the new KYB Gas Adjust shocks in the car and they seem to work very well. It was about the simplest install in the world. Within 15 minutes I had them changed out.
I could tell the difference between the shocks when I depressed each of them to the ground when I had them out of the car. The KYB was slightly harder to push down and seemed to rebound a little quicker. I guess time will tell when I get them on the track in June. Easy upgrade for $34 each.
James
281-804-5730
05-01-2008, 12:53 PM
Cobra Make, Engine: BDR #259 351W
James
This sounds interesting and I want to upgrade mine as well.
Dumb question, do you have any model number available?
05-01-2008, 03:30 PM
tx
Cobra Make, Engine: James Yale made ready BDR#546 Radical Keith Craft 427 SB Dynoed 618hp
Summit racing PT# KYB-KG5529
I only know this cuz I got it from James invoice today. lol
Summit pictures a front shock for that number but it is a rear shock
05-01-2008, 04:46 PM
KYBs are nice. Bilsteins are even better. But in either case it firms things up quite a bit. I think the standard shock is best all around for a cruiser.
05-01-2008, 05:41 PM
Cobra Cowboy
05-01-2008, 09:17 PM
From messing around with all the shocks, I can put them in order from softest to hardest:
Gabriels : Soft
KYB GR2 Standard: Medium
KYB Gas a Just: Medium-Firm
Bilsteins: Very Firm
Hope this helps,
James
281-804-5730
05-02-2008, 05:56 AM
GA
Cobra Make, Engine: BDR - 351 / 385 hp
I replaced my original rear shocks with Bilsteins and have been very happy with the performance and ride. The OEM shocks allowed for a lot of wheel hop with the open differential, while the Bilsteins hold the tires to the road. I also had some problems with the car "bottoming out" with the spring hitting in the lower bucket. That is no longer a problem either.
Speedy
05-03-2008, 05:21 AM
fl
Cobra Make, Engine: backdraft racing 302 ford
What part# on the bilstein shocks for backdrafts
Thanks ED
Ed
05-03-2008, 05:29 AM
GA
Rear shocks from a 1969 VW bug. Bilstein p/n B46-0034-H0 works, need to cut mounting sleeve on lower end.
Speedy
05-04-2008, 05:58 AM
oh
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
I just installed the Bilstein p/n B46-0034-H0. It increased my ride heigth by about 1/2 inch, and they a firm. Have not tested if it resolved the wheel hop yet.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
05-04-2008, 09:22 PM
I officially put about 25 miles on the car yesterday with the new KYB Gas Adjust shocks and I am very happy with the ride. It did not seem tougher at all, but I did notice a significant reduction in wheel hop. The car launched great without any wheel hop on multiple occassions.
I am really looking forward to seeing if these shocks make a difference on the road course.
Bests, James
281-804-5730
05-05-2008, 04:21 PM
fl
Cobra Make, Engine: Backdraft #985 Custom Pro/ Street Race Car, full cage, dry sump 427W and G Force T-56 Fully Street Legal!!
Oh, That's just great. Gotta make it faster eh??
MMM I may have to do some tweaking......
Glad it worked out James, look forward to catching up.
Richard
Off to Sebring in three weeks.....
Life is short, live like you mean it!!
Live every day like it's your last. One day you will be right!
05-05-2008, 06:16 PM
Richard, I've gotta get on the track in order to practice so that I can keep up with you at Run n Gun this year. I look forward to seeing you again soon... Have fun at Sebring and good luck!
James
281-804-5730
05-05-2008, 06:24 PM
http://www.carrerashocks.com/
Do these guys make a replacement shock for the Backdraft?
QA 1 makes a 10 position adjustable non coil over shock
05-05-2008, 08:50 PM
I guess you would need to use one of their universal shocks that have the same travel distance and extended length. Also, the bolts would have to line up as well.
Let us know if you find anything...
Bests, James
281-804-5730
05-05-2008, 09:04 PM
Ne.
I replaced my rear Aldan shocks with QA-1's (twelve way adjustable) and the difference is remarkable.
I may be doing the same for the front.
Iv'e done quite a bit of work with my rear suspension. If you interested, check out my post "Rear suspension problem (Lone Star) and others"
Posted today, May 5th.
I think I have the problem's fixed, and need to up date my post.
It's level, rides a lot better and I'm very happy !
Kevin
05-05-2008, 09:49 PM
on a previous suspension question, QA 1 refered me to these guys
http://www.naake.com/
06-07-2008, 10:13 AM
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
I just replaced the rear Bilsteins with KYB Gas-A-Just and I'm much happier with the KYB's for street driving. The Bilsteins are REALLY firm. If I go tracking I'll put the Bilsteins back on.
Bill
"If your work speaks for itself, don't interrupt"
06-07-2008, 08:22 PM
oh
I put the Bilsteins on about 300 miles ago...they are stiff, I think to stiff for normal street driving. And on choppy roads under hard acceleration in second gear the motor revs (tire spin) on the chop. Sledge...Got a KYB part number? are these VW unit also?
