Old 07-31-2008, 06:15 AM
Default 351w removal
outside of the obvious, is there anything else I should be aware of when I remove my engine? I planning on removing the engine only. Any help would be greatly appreciated.
Old 07-31-2008, 07:29 PM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
It is actually a lot easier to remover the engine and tranny as one assembly. It is much harder to realign the input shaft on the tranny to the engine with it dangling in the air. Also, you will have to find some way to support the tranny in position where the bellhousing is located.
Good luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
Old 07-31-2008, 07:58 PM
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
One important tip if you are doing it in your home garage: be extra careful to not spill transmission fluid on the garage floor. It stinks up the whole house and is tough to get out of concrete.
In desperation after weeks of spousal verbal abuse and threats of impending celebicy, I finally poured muriatic acid from the pool on it and that did the trick.
Old 07-31-2008, 11:17 PM
HI Cobra's Avatar
Just drain the transmission fluid before you pull it if you end up taking it out.
End of problem. If it is going to stay and won't be tilted much then you
should be ok leaving it in. I learned the hard way - big difference!
Flip
Old 08-01-2008, 04:44 AM
wtm442's Avatar
Beam Me Up Scottie
Lots of friends to help and lots of blankets to prevent damaging the paint.
And take your time ... do not rush it. Drink the beer AFTER removal. Not during or before.
Warren
