Like Tree2Likes
Old 08-22-2008, 09:39 AM
HI Cobra's Avatar
That do look nasty - no wonder it was wandering!
Flip
Old 08-22-2008, 10:04 AM
Cobra Make, Engine: Venom 427sc
Amazing that your car is the same color as mine and the break looks exactly the same.
I used a c- clamp to hold tight to the frame so we can move it.
joe
Old 08-22-2008, 05:59 PM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
A c-clamp... another thing I need to keep in my tool roll LOL
Guys, this is *NOT* the front, it's the rear, a failure that occurred in 2005, which I repaired myself with a mig welder. Something similar happened in the front now... but I haven't seen it since I had it flatbedded over to the frame shop, and I'm not sure exactly what the new break looks like.
CobraED, I welded a triangular support underneath each side of the bracket as you said. Fix is solid so far. Flex is obviously the enemy. As you can see from the pics, there was some rust in the crack, so it happened over time.
If I can see you, I'm too close
Old 08-22-2008, 07:16 PM
Correct me if I'm wrong but thats not a cracked weld, thats metal fatigue. The weld looks like its intact.
Old 08-23-2008, 03:18 PM
MrMagoo's Avatar
Yes, thats metal fatigue in the rear, and I assume that is also the case in the front. I have had cracked welds on my headers, but on the frame it's been metal fatigue. The welds on the frame actually look pretty well done from everything I have seen.
Old 08-25-2008, 12:16 PM
Mr. Magoo
Brians buddy picked up my car today and it should be done tonight. If it doesn't i will pick it up tonight.
joeg
Old 08-25-2008, 01:30 PM
MrMagoo's Avatar
Sometimes it's nice to live in New Britiain
Old 08-26-2008, 12:14 AM
Rwillia4's Avatar
magoo,
Did your car alignment work properly? It is hard to tell but looks like the three frame holes were opened up possibly to get it tracking sraight? When I had mine alligned I think they ended up opening up these holes or this purpose. I'm wondering if I need to inspect and possibly install a backing plate.
great pictures documenting the failure.
Old 08-26-2008, 03:52 AM
MrMagoo's Avatar
Rwillia4,
Yes, there is some adjustability in there, the 3 holes are elongated, and it appeared to come that way from the factory. I have not had my car re-aligned yet, but it has always tracked pretty well as it came from the factory.
What would the purpose of the backing plate be? The actual mount, which is bolted on to this tab, has three studs in it... they are only just long enough, so that might be an issue.
Old 08-26-2008, 08:06 AM
Blittleton's Avatar
CC Member / Sponsor
I'm glad that no one was hurt, I'm sure Brian will fix and it will be up to standard. Here is what Backdraft has done since car #50 or there abouts. As you can see in these photos they have added supports to the same area that is mentioned.
www.gcperf.com
Old 08-26-2008, 03:30 PM
Mr Magoo mines back on the road and all the welds in front and rear where checked and ok.
joeg
Old 08-29-2008, 03:42 PM
MrMagoo's Avatar
Hi Joe,
Mines back on the road too. Feels good! I need to do an alignment now though.
I'll post some pics of the repair ASAP. We should hook up!
= Sean =
  #33 (permalink)
Old 08-31-2008, 03:38 PM
MrMagoo's Avatar
Back on the road, here is a pic after the repair.
