Old 05-06-2009, 05:44 AM
Default cam change
I am thinking about changing the cam in my 351 windsor while its still in the car. Outside of the obvious,is ther anything I should be aware of? Thanks for the help
Old 05-06-2009, 06:13 AM
LoBelly's Avatar
I'm going out on a limb here but perhaps you should also try to be aware of the less obvious and obscure as well
good luck
LoBelly
Old 05-06-2009, 07:27 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
I think there was a thread about this a while ago, but I can't recall if it was here or on the BDR boys forum http://backdraftboys.com/forum/
The quickest way to get info on "if it's doable" would be to contact Jay at Vintage.
Doug
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 05-06-2009, 07:52 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Oil seems to be a concern with several people I have talked to.
I am in the middle of the CAM swap on my Boss and have the heads at a NASCAR shop for seats, seals, springs, valve job, CC and a touch up on the ports.
The Oil concern is for break in. I plan to use the Brad Pen stuff to get through the break in and then will switch back to Mobil 1.
Just a bit of info.
Old 05-06-2009, 08:18 AM
FWB's Avatar
FWB FWB is offline
Just a bit of info.
ditto on the Brad Penn
