Old 02-06-2015, 12:16 PM
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
Default Looking for a shop to work on my heads
Aluminum Dart head with one int. valve ground 120 thousands lower than the others. The ex. and int seats overlap so both seats need to be replaced. Both seats need to be reground and the short int. valve needs to be replaced. My engine builder has made to many other mistakes for me to go back to him. So I'm moving on. The two very good shops in Watsonville I know won't do the job because of the overlapping seats. I called Dart but they have a two month turnaround. I'm hoping to find someone in the bay area.
Thank you in advance
Tom
Old 02-06-2015, 01:32 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Tom, call Tom Dillard at Campbell Auto Resoration and ask him that question.
Dave
Old 02-06-2015, 06:44 PM
Cobra Make, Engine: B&B, 427 cu in
Send a message via AIM to cgwitt
Tom
410 B Longfellow Court Livermore, CA 94550
Phone (925) 449-3330
Fax (925) 449-3331
8:00am - 5:00pm PST
Monday thru Friday
I have used TOP of the HILL Performance Center very successfully. I had major suspension work done in addition to brakes and steering. While visiting the shop many times, I observed work being done on major engine components. The owner is a suburb technician and has been a straight shooter. Lots of weekender Cobras in the shop - racing ones too.
Chuck
BACC
Old 02-07-2015, 06:13 AM
Bell & Gaines in Modesto . There's some maybe as good, but none any better.
Old 02-07-2015, 06:13 PM
Cobra Make, Engine: FFR MKIII, 289K
Have you tried Gromm Racing in San Jose, 408-287-1301?
Old 02-07-2015, 10:06 PM
Junior Member
No I haven't. I'll give them a call.
Tom
Old 02-11-2015, 01:07 AM
boblyon1's Avatar
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
Jerry from JNW Engine and Machine in Santa Rosa does head work for racing professionals. Might give him a call.
707-217-8070
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
Old 02-11-2015, 02:42 AM
Default Cost of head against replacing it
Tom Howland Tom It sounds like alot of work to repair this head. Good thing is it's aluminum. Tig in alot of metal to build up the seat area and cut a new seat and install a valve seat. I would check the cost of a blank head and have the parts swapped over with just valve seats being machined to match the valve angles.
Joe B. is in Fresno and has more the 60 years of special work.
You might also save some money and find a guy who can tig and fill in the area. This is a special skill. when done right, last a life time, when not Junk city.
IMO replace the head and swap over the parts. Down the road you might find someone who would be happy to repair it or even Dart. This way you have a spare head if needed and don't loss time for driving season. Just a thought. Rick L.
Old 02-11-2015, 08:30 PM
Cobra Make, Engine: CSX Continuation FIA 289 , Ford
Call Steve at Panavia , San Jose
Marc
Old 02-12-2015, 08:04 AM
Junior Member
Once again no one wanted to do it. The third referral from Top Of The Hill (he doesn't do in house machining) got me to American Cylinder Head in Oakland. Great shop. They have no problem replacing the seats. The owner did a vacuum test on each valve and noticed a valve on the other head was a little leaky. He also saw from the imprint of the head gaskets that they were about to blow. So he will resurface both heads. He's going to tear them down, check everything, fix them, and reassemble them. I'm pleased. Thank you everyone for your help.
Tom
