Old 04-05-2007, 01:38 PM
289fia_cobra's Avatar
Default Recommendation for radiator repair (aluminum)
Anyone have a recommendation for a radiator shop that can work on an all aluminum radiator? I realize that they will likely use an epoxy but just want to be sure they know what kind (not JB Weld). I've developed a leak and will be yanking the radiator this weekend.
My Build Site
Old 04-05-2007, 02:34 PM
Rick Parker's Avatar
Where is it leaking? Tank, fins, header ,etc?
Old 04-05-2007, 02:50 PM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
Hi 289 FIA,
I've had lots of good work done here:
http://www.pankeysradiator.com/
They are in San Leandro.
TR
Old 04-05-2007, 02:53 PM
Not 100% sure yet but initial observation seems to point it at the joint where the right tank and a tube intersect. The leak stops when below the hole; I was topping off the radiator at a T-filler and after about 24oz., I noticed a pretty good drip going on .
I'm going to yank the radiator this weekend and remove the shroud to pin point it but it's high.
My Build Site
Old 04-05-2007, 04:53 PM
I have a product that I purchased that is like a "plastic" or a "hot melt glue" 1/8" diameter coil about 3 ft long. It was purchased from a Circle track supply company. It is intended to be wicked into the affected area after it is carefully heated.
Old 04-06-2007, 08:45 AM
Thanks Tony! Good site. Anyone hear of one in San Jose on Old Oakland Rd.? Someone at work recommended them.
Rick: I assume a Bernz-o-Matic for heat source (like sweating copper?)
My Build Site
Old 04-06-2007, 08:53 AM
Yes, small propane torch. HOWEVER the aluminum fins and tubs are VERY heat sensative and will shrivel and melt instantly when the temprature threshold is exceeded. Repairs on the core or header area of aluminum radiator are next to impossible to do successfully. If the opening of the tube can be accessed by removal of the tank or by cutting a hole in it, you may be able to successfully render the individual tube non functional by plugging it with epoxy. Or maybe by bead blasting from the outside and applying "sealant". Good luck.
Old 04-13-2007, 10:42 PM
What did you find out???
Old 04-17-2007, 04:29 PM
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
I too have had very good luck with Pankeys.
We have enough youth. What we need is a fountain of common sense
