05-05-2008, 11:03 AM
Cobra Make, Engine: SPF#1751 CHP 427
E break busted
Hi Folks
I think the e break cable got busted, I backed-up the car and forget to release the hand brake, do you know where can I buy the cable?
I have not jack-up the car to take a look, but my guess the cable may be broke
Tan
05-05-2008, 11:28 AM
KY
Is there still tension on it?
05-05-2008, 11:42 AM
Yes, I pulled the hand brake and tension still there,but the car still roll backward
Tan
05-05-2008, 11:45 AM
KY
If you still have tension, then the cable isn't broke.
05-05-2008, 11:47 AM
TC - You may need to replace the pads on the eBrake.
Doug
05-05-2008, 11:58 AM
Cobra Make, Engine: SPF #1019
TC, do you have the differential/drive-shaft ebrake disk or the extra calipers on the rear disks? Either way, you probably just need to adjust them...
05-05-2008, 11:59 AM
KY
Kinda what I was thinking....some of these cars have shoes behind the rotors. You may have broken one/two.
05-05-2008, 12:06 PM
Thanks for all the advice and info, I will need to jack up the car and inspect
will keep you posted
Tan
05-05-2008, 12:36 PM
KY
If the e-brake is mounted on the axle housing, you'll probably have to remove a wheel/tire, then pull the caliper/rotor off to get a good look.
05-05-2008, 05:44 PM
I forget which direction to remove the knock-off for the rear wheel
Pls help
Tan
05-05-2008, 06:03 PM
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
I believe they come off in the forward direction. Same direction as tire rotation as if you were moving forward.
05-06-2008, 12:01 PM
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
tc,
For the Knock-offs. Just rememebr the drivers side is normal thread direction the passengers side is a reverse thread. So drivers side is counter-clockwise to loosen passsengers side is clockwise to loosen.
I remember this by thinking my passengers are always a bit different as compared to me the driver?
Rubber peelin' gears a jammin'!
05-06-2008, 01:07 PM
Regularly Offensive
Cobra Make, Engine: spf
All spf.........to remove hit the spinner toward the front....right side or left side no differance..............
Ed
Too close for missles, switching to guns.........
05-09-2008, 08:04 PM
Thanks a lot, this is easy to remember now
