Old 05-05-2008, 12:03 PM
tc_sj's Avatar
Cobra Make, Engine: SPF#1751 CHP 427
Default E break busted
Hi Folks
I think the e break cable got busted, I backed-up the car and forget to release the hand brake, do you know where can I buy the cable?
I have not jack-up the car to take a look, but my guess the cable may be broke
Tan
Old 05-05-2008, 12:28 PM
Is there still tension on it?
Old 05-05-2008, 12:42 PM
tc_sj's Avatar
Yes, I pulled the hand brake and tension still there,but the car still roll backward
Tan
Old 05-05-2008, 12:45 PM
If you still have tension, then the cable isn't broke.
Old 05-05-2008, 12:47 PM
Got the Bug's Avatar
TC - You may need to replace the pads on the eBrake.
Doug
Old 05-05-2008, 12:58 PM
Cobra Make, Engine: SPF #1019
TC, do you have the differential/drive-shaft ebrake disk or the extra calipers on the rear disks? Either way, you probably just need to adjust them...
Old 05-05-2008, 12:59 PM
Kinda what I was thinking....some of these cars have shoes behind the rotors. You may have broken one/two.
Old 05-05-2008, 01:06 PM
tc_sj's Avatar
Thanks for all the advice and info, I will need to jack up the car and inspect
will keep you posted
Tan
Old 05-05-2008, 01:36 PM
If the e-brake is mounted on the axle housing, you'll probably have to remove a wheel/tire, then pull the caliper/rotor off to get a good look.
Old 05-05-2008, 06:44 PM
tc_sj's Avatar
I forget which direction to remove the knock-off for the rear wheel
Pls help
Tan
Old 05-05-2008, 07:03 PM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
I believe they come off in the forward direction. Same direction as tire rotation as if you were moving forward.
Old 05-06-2008, 01:01 PM
Mike Bartlett's Avatar
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
tc,
For the Knock-offs. Just rememebr the drivers side is normal thread direction the passengers side is a reverse thread. So drivers side is counter-clockwise to loosen passsengers side is clockwise to loosen.
I remember this by thinking my passengers are always a bit different as compared to me the driver?
Rubber peelin' gears a jammin'!
Old 05-06-2008, 02:07 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
All spf.........to remove hit the spinner toward the front....right side or left side no differance..............
Ed
Too close for missles, switching to guns.........
Old 05-09-2008, 09:04 PM
tc_sj's Avatar
Thanks a lot, this is easy to remember now
