Old 11-24-2009, 09:13 AM
Cobra Make, Engine: Classic Roadster, .30 over ford cleveland 2v heads 400 hp
Default rubber grommets for bumper studs
I have 1 1/4 inch O.D., (outside diameter), bumper tubes that came with my CR kit. Where can I get the rubber grommets for these tubes?? As always I appreciate the info.
Old 11-24-2009, 09:34 AM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Neutral
I have a bag full of them!!!
PM me your shipping info and I'll send you some
"the other ed"
Old 11-24-2009, 03:47 PM
Double Venom's Avatar
Cobra Zach,
The two top FRONT tubes take the large "O' Rings, the ones on the rear use 4 smaller ones.
Thought you might like to know.
DV
CptEddie I think I dumped both sizes into the one bag ??
Old 11-24-2009, 07:23 PM
PM sent Capteddie
Old 11-25-2009, 04:53 AM
Just to clarify, I apparently lost some people because all four tubes, front AND back ARE the same diameter.
The size difference is for the angle that the front grommets need to be to fit tight against the body. On the back they fit 'flat' there fore a larger grommet is not needed.
DV
