Old 11-25-2009, 05:14 PM
sunman's Avatar
Default 8.8 rearend disc brake question
I've installed 5 lug axles in my 86 Mustang 8.8 rearend and am using the disc brakes off of a 86 Mustang SVO 7.5 rearend, which was a 5 lug from Ford. Is there a caliper bracket off of another Ford or Lincoln that will work? The 7.5 bracket does not work. Do I need to make them? Any info welcomed. Thanks,Sunman.
Old 11-25-2009, 08:34 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
i know mike fort'e from forte's parts connection sells them, also if you go to the ffr forum and look under advertisers there is a company called diskbrakesrus they sell them also, i hope that helps.
Old 11-26-2009, 03:04 AM
PANAVIA's Avatar
Check into the \\ 1985 Full size lincoln town car rear, and the 1987-88 Ford thunderbird turbo coupe rear.
That should be the right ones.
Old 11-26-2009, 09:14 AM
sunman's Avatar
WRENCH87
PANAVIA
Thanks for the help. I'm still preping parts and have not started car build yet but I've stopped everything to read every thread listed. You guys are great. Manual? Don't need no stinking manual!!!
Sunman
Old 12-24-2009, 09:24 AM
Cobra Make, Engine: CMC,Ford 302
Default Disc brake brackets
I found out the hard way that an 8.8 from a 94 mustang was wider than the Fox body 86-93 mustang. I read an article in a Ford magazine that told about a way to convert the 94 disc set up to work in the earlier mustangs. Richard Oben @Northracecars.com 816-436-1610 sells brackets and hardware to bolt the calipers right up.
Old 12-24-2009, 09:47 AM
Default 8.8 brake brackets
Give Richard Oben at Northracecars.com a call. His company makes brackets to convert one model 8.8 rear to anothers calipers. Phone no. is 1-816-436-1610. He got me the parts needed to convert a 94 mustang with disc brakes to the width of a fox body mustang. (86-93)
Old 12-24-2009, 12:35 PM
sunman's Avatar
DonB
Thanks for the help. I'll call them on Monday. I haven't bought anything yet and I'll update when I finish caliper mount.
Merry Christmas and God Bless
SUNMAN
