Old 04-17-2010, 08:33 AM
Cobra Make, Engine: classic roadster,408cu
Default clutch cable
Does anyone have a source for the 79 mustang clutch cable ? ford says its an obsolete part and napa says its out of stock? WD
Old 04-17-2010, 08:45 AM
Would you be interested in an aftermarket cable?
Old 04-17-2010, 12:45 PM
Cobra Make, Engine: FFR3985:
fortes has them. . . (I think)
Old 04-17-2010, 03:40 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
i GOT MINE FROM jEGS IT WORKS JUST FINE
Old 04-17-2010, 03:52 PM
Mark, Did you break yours? I have an extra one here that you can borrow until you can get another one.
Terry
Old 04-18-2010, 08:26 AM
Terry , no it didnt break the jam nut came off and I lost travel , i called about getting the domed piece of hardware that goes on there and found out that they are scarce .
I thought having a spare was a good idea...WD
Old 04-18-2010, 08:50 AM
Ron61's Avatar
Post
If you have enough cable length you might do what I did. After I got mind adjusted I was worried about the jam nut and that little dome piece so I used some of the extra cable and untwisted about an inch of it that was sticking out and wrapped it back over the piece with the jam nut and taped it. Since it was out of sight no one could see it anyway. On the other end in case of need for future adjustments I just taped the piece that was past the jam nut.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-18-2010, 12:23 PM
Mark,
The domed piece of hardware that is on my extra one is nothing but a 1/2" long hex nut that is chamfered/radiused on one end.
Terry
