Old 05-23-2010, 02:56 PM
Default WTB Upper and Lower Radiator Scoop
I am fixing a 1995 CR 427AC that has a damaged upper and lower radiator scoops. The lower is easily removed while the upper is resin attached on top near the top. Does anybody have a spare set? Any help would be appreciated.
Old 05-23-2010, 05:14 PM
Double Venom's Avatar
HP,
unfortunately the "TOP" like you say is glued in. It is NOT a piece that is sold with the kit, it IS a part of the kit.
I've made a buck for the lower, if you want I can make you one for $45.00 including shipping? Bring it to Pentwater, I'll build you the upper. What's 1,500 miles!
Old 05-24-2010, 10:06 AM
onefastmustang's Avatar
Does anyone have a picture of what these look like? I had been contemplating making something like this for my CR.
Old 05-24-2010, 07:29 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Use sheet aluminum available in Lowes or Home depot and form your own .Rivet into place. Paint them or polish the aluminum , I'm thinking of doing that on my car even though mine are not broken.
Old 05-24-2010, 08:51 PM
Page 13 in my Gallery toward the bottom of the page, I think pg 14 also has some of the aluminum I use for the nose. I use 12" wide roofing flashing then trim to fit. comes in rolls from 12'(?) to 50' (?). A 12 foot roll is enough. Pictures are of Cpt Eddys Or (?) the one I built before his?
Old 05-24-2010, 10:01 PM
capteddie's Avatar
Send a message via AIM to capteddie
"the other ed"
Old 05-25-2010, 08:32 AM
Oh.. I already have that on my car.. did it last winter. I thought this was something for the inside the of the radiator like a shroud that I have on my oil cooler.
Old 05-25-2010, 03:03 PM
Cobra Make, Engine: Classic Roadster II
Has anyone ever had a problem with rocks or anything coming up in the radiator? I was considering putting a rock guard screen right in front of the radiator?
Krewton
Old 05-25-2010, 04:48 PM
no but I did get a bird in there once.. Now that I have an oil cooler and driving lights the space free to get in there is greatly diminished.
Old 05-25-2010, 06:41 PM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
I collected a rather large balloon. Fortunately, I saw it go in and pulled over and set it free.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
Old 05-25-2010, 06:59 PM
Cobra Make, Engine: classic roadster,408cu
Speedway makes a honeycomb panel that the dirt trackers use its supposed to flow 90% of the air through it ..WD
Old 05-25-2010, 08:00 PM
Cobra Make, Engine: 91, 65 CR 427 289 or 302
DV:
What do you use to cut the aluminum so evenly? The only thing I can think of are tin snips and they make an absolute mess of it.
Also I just installed a new VDO voltage gauge. I used a spare wire from harness behind the dash that is hot when key is turned on and grounded to my wiper motor. But I get a reading of almost 16 volts, the max on the gauge, when I turn the key on. Same with engine running. Plus, when I kill the power the gauge goes to zero real slow like a fuel gauge. Odd. Any ideas?
Thanks, Jim
Old 05-26-2010, 05:08 AM
Jim,
Should have it's own dedicated ground. I'm assuming it is still reading from the alternator as it winds down.
Cutting the aluminum? Ue a small pair of scissors, Medical scissors work best for me. Doesn't tear up the aluminum and allows for cutting larger curves. Nice and neat with just s little practice.
