January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 09-17-2010, 02:05 PM
Cobra Make, Engine: Classic Roadster 427
Default Radiator
Anyone know of a radiator that will fit a CR and has lower outlet on driver side? The one I got with my kit has Chevy setup even though I ordered kit for a Ford small block. I'm trying to set up with passenger side inlet water pump from an early Bronco but now my pump mounting bolts and alternator bracket won't work.
Wayne
1st MIBARS
Det.A "The Old Sawmill"
Bien Hoa 1968
Old 09-17-2010, 06:42 PM
Is it an aluminum or brass/copper radiator ???
maybe you could just take it to a local shop and have them change it for you.....
and have them check to make sure its not a dual pass radiator....
Old 09-18-2010, 09:41 PM
Cobra Make, Engine: Classic Roadster Ford 302
Default Rad
I picked one up from speadwaymotors.com, had to do some fancy hose work but it works well. I have pic's if interested.
matt
Old 09-18-2010, 10:30 PM
bobcowan's Avatar
Takes yours to a radiayoer or welding shop and have a new outlet welded in, and the old on closed off. It's a pretty simple procedure. Probably a lot cheaper than buying a new radiater.
Old 09-19-2010, 11:26 AM
Default Pt #
Here's the part #
FORD/MOPAR TRU-KOOL RADIATOR
Item #: 917348
cost 139.99 + shipping 24" wide x 19" tall
Works great with my 302 ford motor.
Old 09-20-2010, 12:43 PM
Are there any issues concerning the mounting of the 19" high radiator and clearance of the hood hinge?
(I have the 26" x 19" Griffin)
Jeff.
