1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
11-17-2010, 08:21 AM
Pic of my CR
New member, thought I would show a pic of my old CR. Still running strong!
11-17-2010, 09:22 AM
Mi
Very nice.
How about some history, specs?
DV
11-17-2010, 10:10 AM
Originally Posted by Double Venom
Very nice.
DV
Traded for the car. As far as I can tell it is an early 90's car. It has a 351 Ford racing motor, 780 CFM Holly, custom hyd cam, hi flow water pump, griffin alum. radiator, electric fan, Holly fuel pump, Ford 9" rear with posi, 411 gears, winters aluminum center section, nascar floating axles with 4 wheel willwood disc. brakes.
11-17-2010, 10:18 AM
TX
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Beautiful car....welcome aboard
Russ
11-17-2010, 11:02 AM
MN
Cobra Make, Engine: B&B, FR302
Welcome. I always liked the looks of a yellow Cobra!
11-17-2010, 11:40 AM
Mi
With those 411's are you running a T-5/Auto?
11-17-2010, 12:40 PM
FL
Cobra Make, Engine: Titanium/Black BDR934, Ford
Very, Very Nice, Congrats!
Do all CRs have the longer doors? is this for a longer wheelbase car?
Fred
Titanium/Black BackDraft Racing 934
351 Windsor
11-17-2010, 12:57 PM
VA
It is interesting that in the 60s during the muscle car period, you could order performance packages or "drag pack" options that would get you 4.11 gears in a normal street car. The icing on the cake is that during this timeframe, there were no overdrives around either in automatic or stick shift. High gear (third or fourth) was a 1:1 ratio.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
11-18-2010, 12:25 AM
Mi
Fred,
Yes, CR's only had one model Cobra, 94" WB, most of the length was made up in the doors.
11-18-2010, 12:51 AM
FL
Fred,
Thanks for the explanation; I had seen a Cobra replica at auction with doors like that but never knew which replica it might have been till now...
Fred
351 Windsor
11-18-2010, 08:50 AM
Ca.
Fred,
What you seen could also have been an Emerson. Theirs look very similar. www.beyondcobra.com
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
11-18-2010, 02:26 PM
Mi
Terry,
Emerson's IS a CR Cobra but by now very much modified!
11-18-2010, 03:46 PM
Ca.
DV,
Yea I know. I just did not want to say that they splashed a CR body and then modified it to suit their needs. But Bill has said that himself so it should not bother me to say it. But it does a bit.
Terry
11-18-2010, 06:50 PM
5 speed tranny.
11-19-2010, 03:59 AM
Mi
Terry,
Nothing wrong with that, Bill just made changes to fit his stye. The "Emerson" Cobra is a great car. He (Bill) still continues to amaze me!
But who am I to debate changes to a long standing leader of the industry?
4:11's with a T-5!? HOLD ON! - WE'RE OUTTA HERE!
11-19-2010, 09:08 AM
Ca.
DV,
What's wrong with 411's and a T-5? Besides the fact that it tacks out fast and will set you back in the seat when you stomp on the loud pedal . Yea, even with only a mere 350HP.
Terry
11-19-2010, 11:21 AM
Mi
Absolutely NOTHING! I meant exactly as you said! "The only thing left is the tire smoke and a memory!
11-19-2010, 12:55 PM
Ca.
Yea, I get it. I need to change mine to at least 370's or even 355's. What do you think would be best?
Terry
11-19-2010, 01:13 PM
Mi
Terry,
Wow hard choice for an answer through e-mail. The original "DV" had em all but it also had a T-6 for the tranny. I finally gave up drag racing and before raffling it off for my last DV Spring Fling we had 3.73's in it. They really worked nice. I guess I would still go 3:55's, or 3.73's with a T-5. (355 HP or more)
11-19-2010, 02:59 PM
Ca.
I was heading more toward the 370 range myself. I guess I really need to check transmission gear ratio and tire size then figure it out from there. I just know the 411's don't get it for me. Maybe years ago, but not now.
Thanks DV.
Terry
