Old 04-13-2011, 11:36 AM
Default Transmission Mount
I've got a 351W with a '94 T5 tranny.
The manual calls for a 2" tranny mount.
I have an Energy Suspension mount that appears to be 2 1/2+" tall.
On the first build, I flipped the mounting bracket for the tranny mount over and attached it to the frame with 1/2 spacers to make up for the difference in the tranny mount.
The reason I did this was the fact that without the spacers, the angle of the engine in the frame from front to back was such that the side pipes would not match up with the attachment points and had to be lowered; hence the spacers which lowered the transmission and engine angle.
On this rebuild, I would like to use the proper mount if it exist for my set up described above.
Any comments or advice is greatly appreciated.
Jeff
