January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 10-28-2011, 09:10 AM
yeller53's Avatar
Question Grommets
Anyone know where to purchase front bumper grommets that will fit on a tube with a 1.25" OD and will form to the body front ?? Thanks for any help !!!
Old 10-28-2011, 09:35 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Here you go....
Finish Line Accessories
Jack
XSSIVE .....
Old 10-28-2011, 09:45 AM
yeller53's Avatar
Unhappy
Thanks, but Finish Line don't have the size I need. 3/4 OD is the largest they carry.
Old 10-28-2011, 10:22 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I think most use 3/4" bolts to attach the bumpers, the finished look comes from "sleeves" that slip over the bolts and would not need to go into the grommets, only against them.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
Old 10-28-2011, 11:43 AM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Try these. You have to buy 25, but they're only $14.
McMaster-Carr
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 10-28-2011, 12:02 PM
FWB's Avatar
FWB FWB is offline
this company has a huge product selection
Products | Grommets, Gaskets, Extrusions, Stripping, Vibration Isolators, EMI Shielding and more for the OEM marketplace | Western Rubber & Supply Inc
Fred
Fred B
Old 10-28-2011, 01:14 PM
Cheers!
Dugly
Dugly,
The "sleeves" on a CR runs all the way from the bumperettes/quickjacks to the frame. They need to be larger for the CR.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 10-28-2011, 01:16 PM
You might want to check with DV. He might have a bunch laying around in a bag somewhere. Or at least he could give you a part number and manufacture/supplier where he gets them.
Terry
Old 10-28-2011, 04:13 PM
yeller53's Avatar
Neutral
Hope DoubleVenom checks in and can help. I think they need to be oval. I'm not sure how to contact him.
Old 10-28-2011, 05:04 PM
I think DV only comes to CC every couple of days or so. Hang in there.
Terry
Old 10-29-2011, 03:49 AM
Double Venom's Avatar
Ya, having to drive a few miles at 3:30 AM to get Wi-Fi is a pain in the arse.
Yellar; you have to use regular grommets, about an 1"-1'/4 for the front and 1" for the rears. You cut the grommets down the middle leaving you two O" rings from each grommet. Then VERY carefully use "Crazy glue" that has been made to actually glue to rubber! The front grommets will stretch to fit the angle of the front tubes.
On the rear I don't use any glue. This way you can pull the rubber- grommets away from the body when you want to wax the car, then push them back.
I get them from Kimball-Midwest, Col's, Oh. Mc Master Carr should have them too.
Sorry I used my last four, but if you have any trouble contacting Kimball I'll get you there phone and salesman on next visit!
DV
Old 10-29-2011, 07:17 AM
yeller53's Avatar
Thanks DV and everyone else for your response !! I did'nt think about splitting them on the front. I'll give it a try. Again, Thanks everyone !!!!!
Old 10-29-2011, 07:28 AM
Guys,
I used the tubes and grommets from finish line on two classic roadsters. It was a very easy modification, the threaded rod is 1/2" diameter, the sleeve material fits right over the rods, and you make the holes in the body to fit the grommets from finish line. Piece of Duff, mate!
Old 10-29-2011, 10:00 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Try Lowes or Home Depot . I got mine a Lowes.
Old 11-02-2011, 07:38 AM
NO disparment intended but FINISHLINES Grommets are for a FFR NOT a CR! CR's bumber tubes are almost if not more than TWICE the size of FFR.
If you get tagged or worse you 'tag' someone else I would think you would want all the bumper you could get!
Finally found Kimball-Midwest card:
Michael McPhilimy, 1-800-214-9440 X 2018
If he has trouble finding them (The right size) ask him to pull my files (Ed Combs) they should have a record of orders. Remember I order two sizes, one bigger than the other!
DV
Old 11-04-2011, 05:04 PM
yeller53's Avatar
DV,
Did you still have to split the front ones or will the ones you suggested conform without splitting in half ? Thanks for your help. It will be Mon. before I can check back in. yeller53
