Old 12-30-2012, 06:00 PM
Cobra Make, Engine: Classic Roadsters II, Ford
Default sway bars
Iv,e read most of the discussions on sway bars but I would like to install one anyway . Does anyone have the original Classic II front sway bar for sale and do you use the original Must. II end link kits ( moog # K8229 ) ?
I have a rear sway bar I,m guessing from a fox mustang , it is 13/16 " in diameter and will fit the rear suspension set up .
I don,t know what the original front sway bar was , but how will this setup work for me . I,m using a 572 cid BBF with toploader and 9" rear for powertrain .
Old 01-03-2013, 03:33 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
I have both the front and rear CR OEM sway bars and am willing to part with them. Where are you located?
Old 01-04-2013, 02:55 PM
Neutral
Hi Curt
I live in Canada but will be leaving Jan. 10 on a road trip to Las Vegas . What are the diameters of the bars ? Does the front one come with frame mounts and end links ? I have a rear bar that fits and is 13/16" in diameter , so if yours is the same would you sell the front one only ? How much are you asking for both bars or just the front one ? You can e-mail me at : rpetrowski@shaw.ca
- Rick
