Old 07-17-2014, 01:42 PM
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default My novel solution to incorporating a firewall adjuster on the CR Cobra
Considering that the 79 Mustang clutch I got was had allot of resistance on the cable itself and to use a newer style cable meant using a even longer tube, I decided to give a try and incorporate a Firewall adjuster.
The firewall adjuster I am thinking will make it allot easier to adjust the clutch.
While not pretty I think that using PVC and the flange base will be more than stable than enough.
Anyways what do you think?
I am going to clean up the mounting flange and paint the PVC black.
