| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
09-26-2014, 02:52 PM
KY
Cobra Make, Engine: 91, 65 CR 427 289 or 302
Were 302's installed originally altered?
Does anyone know what kind of 302's were used for the turn-key builds done by Classic Roadsters in 1991? I have a 1991 built by them with a 302. I have no idea if they used rebuilt 302's, or modified, altered, juiced up, tricked out 302's, crate 302's or what. I can't see inside the engine obviously so I don't know if it has been ported, polished, a roller cam and so on. Any one have a 1991 build by them that has a 302 and knows anything about the engine?
Be a big help if you do. Thanks.
09-26-2014, 03:19 PM
Wi
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
I doubt they were tricked out in any way. I would guess it's a "standard" crate engine.
09-26-2014, 03:31 PM
tx
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Put it on a dyno, that will tell you pretty quick. Does it have the standard GT fuel injection intake? If it is stock, it could have less than 200 HP.
" It ain't no big deal"
09-29-2014, 08:27 PM
KY
It has an Edlebrock aluminum intake, custom headers and an MSD ignition. Also a Holly 4-barrell. If it was a "crate" engine does that mean it was new or a rebuilt one? I thought I saw someone on here with a turn-key 1991 302 CRII. Don't know where I could get it dyno'd around here. Jim
09-30-2014, 04:58 AM
Wi
I understand the frustration of not knowing what the internals are. I have a sbc 327 that I really wish I knew what type of cam it has in it. I all I know is that it must be a pretty big cam.
Considering that your engine has a holly carb, Edlebrock intake, it was a short block rebuilt engine. CR then added the intake, carb, water pump and pulleys. I don't see them ordering direct from Ford, but who knows.
09-30-2014, 08:34 PM
Mi
If I had to guess (?) almost all of CR Cobras were built from DONOR cars.
10-01-2014, 02:02 PM
KY
Thanks. I hope it was at least a rebuild. But it is strong and compression is right up there on top. No leaks, no using oil, etc. But when I talk to a potential buyer they want to know if it has been bored, stroked, ported, cam'ed, polished, electrified, modified and gentrified. All I can say is I have no idea but it runs extremely well.
10-01-2014, 08:09 PM
Mi
Jim,
If I may...find a Dyno, get a printout of the results. Then you can say "I don't know, but here's the dyno sheet! No lies,fibs, maybe's---just the facts!
