Old 06-16-2016, 05:21 PM
Cobra Make, Engine: 1997 CR, 351c
Default Another master cylinder question
So my car developed a brake fluid leak from the m/c, I pulled it off this afternoon but I'm having a hell of time finding a replacement. I've searched the forum and it seems most people have a mustang II or corvette m/c installed. Mine has two different size reservoirs but my hose connections are facing the engine. The bendix part #2231591 Google search hasn't turned up anything either plus the local auto parts stores are baffled too. The car has 11" four wheel disc. Any ideas? Thx
Old 06-16-2016, 07:47 PM
NAPA shows stock.
2231591 | NAPA Auto Parts | - Buy Car & Truck Parts Online - NAPA Auto Parts
Old 06-17-2016, 03:13 AM
That looks like it! Here's where I get confused because I'm a newbie, it says the bore is 1 1/8" but the part of my m/c flange OD that goes into the booster (not sure of terminology) is 1 1/2". Is the advertised bore the id?
Old 06-17-2016, 04:44 AM
The 1 1/8 should be the cyl id. The complete booster / master cyl Assy is PN 50-3208. Approx $130.
Old 06-17-2016, 09:30 AM
Awesome, thx
Old 06-22-2016, 02:52 AM
Double Venom's Avatar
Not to confuse matters, for what it's worth because I don't know..... BDR &CR the same(?) you describe you CR brakes. This unit does use the Corvette booster /MC.
What you are describing and can't locate is one in the same M/C.
You can order it with left, (fender side) OR Right (Engine side) Ports.
DV
Old 06-30-2016, 03:38 AM
After contemplating changing the whole booster/mc assembly I decided to replace just the mc with the Napa unit, works great and no more leaks. thx for all the input.
