Old 10-26-2017, 07:02 AM
Cobra Make, Engine: Classic Roadsters Ltd. small block ford 347cid.
Default Classic Roadster weber setup
Has anyone out there put weber's on a classic roadster cobra car, with a small block?
I am wondering about hood clearance, with the small scoop. Any information would be appreciated.
Also wondering if they can be run without an overflow tank. Thanks, Neil
Old 10-26-2017, 04:11 PM
Gaz64's Avatar
There are plenty of threads on here if you use the search function.
"Weber" is the first word to try.
Also go to Weber tuning in the Engine Building, Tuning and Induction section.
Old 10-28-2017, 10:33 AM
*13*'s Avatar
302 block or 351? I can measure bottom of manifold to top of horns on my 289 setup, if you need
ERA FIA 2088
