Old 03-13-2018, 06:45 PM
Cobra Make, Engine: 302. 1992 build
Default 302
This is Bulldog again I have a question my cobra has a 302 engine . the heads on it have only a marking as a T i guess a truck head but I can't find much about these heads any info. Would be helpful .Are these heads ok for a 302 car seems to run strong ? Thanks
Old 03-13-2018, 07:10 PM
Cobra Make, Engine: FF 289Comp #8955
There should be a casting number either on the top valley of the head, or it may be underside on the intake side. If you can find that I can look it up in a book I have.
Old 03-16-2018, 03:52 PM
Default 302
Thanks peter I will check that out and reply
Old 03-17-2018, 05:28 PM
Default 302
PeteH. Could not fin any markings on heads other than the letter T under valve cover and on outside edge on front passenger side of head.may have been painted over will continue to look . thanks. Bulldog
Old 03-18-2018, 08:50 AM
Casting number will be very obvious if they are in fact Ford heads. May start with CAE type prefix.
Old 03-18-2018, 02:37 PM
FWB's Avatar
FWB FWB is offline
head will have to be pulled to see casting number, its on the raw casting under the intake area
Fred B
Old 03-18-2018, 03:48 PM
Default 302
PeteHh thanks again will keep looking .Bulldog.
