Roll bar
http://www.clubcobra.com/forums/classic-roadsters-ii/141153-roll-bar.html)
| Bulldog |
07-02-2018 03:38 PM |
Roll bar
Hey, guys about to add a roll bar to car a single loop for driver and passenger.gueston is what size bar should I use is 1.5 inch about right? Thanks Bulldog.
| trularin |
07-02-2018 04:09 PM |
If you are using a finishing ring and gasket, check with the supplier. Get the parts and then make/order the bars.
Just my opinion.
Tru
| Bulldog |
07-02-2018 07:13 PM |
Roll bar
Thanks Tru , will check suppliers.
| RockBit |
07-02-2018 09:39 PM |
If you are talking about a single wide loop covering both driver and passenger with no third leg brace, the ones I see are quite a bit larger than 1.5 inch diameter tubing.
If you are talking about the more conventional cobra hoop, one for driver and a second one for passenger, those are commonly 1.5 inch. Some cobra makes use larger tubing even for these.
| Ron61 |
07-03-2018 04:00 AM |
I had the single bar in mine that went all the way across and it was a 3 1/2 inch diameter.
Originally Posted by RockBit
(Post 1447642)
| Chicagowil |
07-03-2018 04:37 AM |
I believe Wisconsin Snake had a bar made recently
| Bulldog |
07-03-2018 06:52 AM |
Bar
Thanks guys for the info.
| All times are GMT -7. The time now is 03:49 AM. |
