November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-11-2018, 07:31 PM
Cobra Make, Engine: 302. 1992 build
Default Alternator
Guys thinking g about changing my alternator to a 75 amp car has a 60 unit now.Will 92 classic roadster wiring handle this size alternator? Bulldog.
Old 08-11-2018, 08:29 PM
You should be fine as the alternator only produces what the system demands of it.
This article on Amp ratings and data plate markings is helpful.
https://www.lifewire.com/understandi...ratings-534785
Old 08-12-2018, 05:14 AM
Ron61's Avatar
I used a 100 Amp Alternator in my Classic Roadster for years and never had any problems. As stated above, the alternator just puts out what is needed and doesn't run at full capacity much of the time if any.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 08-12-2018, 01:34 PM
Default Alternator
Thanks guys just what I needed to know
Old 08-18-2018, 08:03 AM
BAsque1's Avatar
Try these guys
Ford Alternators
This is a single wire connection they are fabulous.
Basque1
Old 08-18-2018, 09:33 AM
bobcowan's Avatar
Yes, the alternator will only produce what is needed. But if you need to upgrade to 75A, then you must have a need for that many amps. If it was only going to produce 50A, then that's all you need and what would be the point of the "upgrade"?
So, going on the assumption that you need 70-75A, you might need to upgrade the wiring. You'll need to look at what you have already, compare it to an ampacity chart, and go from there. https://www.cerrowire.com/ampacity-charts
If you need more wire, you can either remove the present wire and add the proper size, or add a second wire. A Painless harness has two wires. You connect the second one if you're using a high amp alternator.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 08-20-2018, 11:26 AM
cycleguy55's Avatar
Originally Posted by BAsque1 View Post
Try these guys
Ford Alternators
One-wire alternators have one benefit - they're easier to wire. Beyond that three-wire alternators are superior. Here's a good comparison: Catalog
I'll also reinforce the notion that wiring should be looked at when upgrading alternators. Existing wiring may have worked just fine for the 60 amp alternator, but may have been 'just okay' or marginal. Put a 75 amp alternator in there and marginal may become under-sized. While it's true the alternator will only output what's necessary, what happens in a scenario when you run the battery down and perhaps get a push or jump-start? The alternator then produces full output while trying to re-charge the low battery and that could become a problem if the wiring isn't up to the task. Better safe than sorry.
Brian
Old 08-20-2018, 11:40 AM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
x2 on the three wire alternator.
Chris
