Old 09-18-2019, 12:19 PM
Default Wring - Engine Stopped suddenly
I have a CR Sebring: Ford 5.0 HO 9189 fuel injected and stock, 5-speed, 8.8 4-link rear. the engine just dies suddenly while diving in 4th gear at about 50 mph. This car has the GM steering column and ignition switches, fuse panel by driver's left knee. Here's what I know:
I replaced the TFI ignition module . wasted $60, should have done proper troubleshooting.
Engine cranks over nicely.
There is no voltage (actually 0.6 VDC) to ignition coil or EEC relay.
all other electrical components work perfect: fuel pump, lights, horn, flashers, etc. Amp light comes on and amp meter on dash reads strong voltage but less than 12 (~11.5). DVM measures 12.5 VDC at battery.
The "gost" voltage (0.6 VDC) at coil and EEC relay are the same so i think there is continuity between them.
So, seems to me that somewhere between the ignition switch and the coil there is a break in the circuit.
The build manual I have does not seem to match my car so I don't know how the output from the ignition switch goes to the coil. The engine wiring harness seems correct for the engine with all wires colored as in the ford harness.
Any ideas?
Does anyone have a build manual with wiring diagram/instructions for a CR Cobra or Sebring from that era - 1989?
Thanks.
Keith
Old 09-18-2019, 02:20 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Check if you have 12 v at the coil with key on. A coil needs 12v constant on positive side and an interrupted on- off ground to fire.
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 09-18-2019, 07:58 PM
Thank you.
There is no voltage to coil nor the relay that activates the computer. Ford wiring harness shows that as a single circuit directly off of the ignition switch with a fusible link in the line.
I don’t know where to start looking for the problem but it clearly resides between the ignition switch and coil. I just don’t know how to locate where and follow that wire.
Old 09-18-2019, 09:41 PM
Default fuse link
Hi,
the fuse link is a 10 ga wire from the starter solenoid, yellow probably. you can check there for 12 v but will probably have to cut and replace that fuse link at the starter solenoid.(disconnect battery 1st)
"The ignition switch gets power from the two yellow wires that are supplied power by a fuse link located in the wiring harness that connects to the starter solenoid."
Perry.
Old 09-19-2019, 03:13 AM
Cobra Make, Engine: FFR 347
Pull the eec relay (also, disconect the coil wire from the coil), check for 12v coming to the relay, jumper a wire across and check 12v past it at the eec (might want to disconect the eec. Having a loose ground , loose 12v, corrosion in a wire or at a plug or a relay that has burnt contacts could give you a low voltage
Also, With the power OFF, use your OHMs setting on the meter and check continuity of the wire itself from one end to other. Set it to the diode setting if you have it, and the meter will give you a strong beep?? Sound if you have continuity. You may have to disconect the wires from where they go! As in pulling the eec or its relay, disconect the coil wire from the coil etc. this will also check the fuse links (just noticed you stated 0 v at the eec and coil and i am not looking at a wiring diagram at the moment, so parts of the above it seems you already know!)
You could jumper 12v to the eec relay and see if you have 12 v at the coil then you know its a wire under the dash and not engine compartment for the coil!
Old 09-19-2019, 02:44 PM
Thanks for some great advice. Pretty much where i was going next. I'll let you now how it turns out.
Old 09-19-2019, 05:13 PM
twobjshelbys's Avatar
Perry
Alot of this is not correct if you have a capactive discharge electronic ignition, like a MSD box. If you do check the book on how to measure spark.
Tony
CSX4005LA
Old 09-20-2019, 05:10 AM
Gaz64's Avatar
Keith's specs seem unlikely to have MSD CDI ignition, so Perrys statement of 12v on the coil positive, and interrupted ground on coil negative would be true in this case. Normal for any inductive spark ignition.
Gary
Old 09-20-2019, 08:02 AM
Default MSD not all that reliable?
Hi,
3 cobras going north out of Reno in the middle of nowhere...…….
the leader Fred's cobra backfires and dies, coasts to a stop on 2 lane road
I pull out my meter and check things. 3rd cobra goes back to Reno 45 miles to summit racing and gets another msd box while Fred and I take out his existing box, no small feat at side of road. 3 hours later back on the road. His msd probably died from the heat in his engine bay. I also ran an msd but it was mounted in the passenger foot box and never had a problem with it. Just one story of the 55,000 miles I put on my 1st cobra
Perry.
Old 09-20-2019, 11:23 AM
cycleguy55's Avatar
Ford EEC-IV/TFI-IV Electronic Engine Control Troubleshooting
https://therangerstation.com/tech_li...agnostic.shtml
Fords Without a Check Engine Light
  1. Start the vehicle and let the engine warm. Then, turn the engine off. [Note: yes, I'm aware the car won't run. Obviously you will have to skip this step.]
  2. Set the volt meter to read between 0 and 15 DC volts. Connect your volt meter's positive lead to the postive terminal on the Ford's battery. Then, connect negative lead to the self test outlet's grounding slot.
  3. Connect the self test outlet's signal return slot to the self test input with a jumper wire.
  4. Turn the Ford "On," but do not start the engine. Count the times the needle sweeps. There will be a small pause between numbers within the code. Code 14, for example, will have one needle sweep, followed by a pause and then four more needle sweeps. Long pauses indicate the beginning and end of a new trouble code.
http://diagnosecarproblems.blogspot....rd-eec-iv.html
Brian
Old 09-27-2019, 10:51 PM
So here’s the story. There is a circuit board on which are mounted all of the fuses and some relays. The terminal at the top fuse is where a black wire goes to the red and green wire in the engine wiring harness. The terminal failed. The next fused terminal below it was also switched off of the ignition and empty. Simply moved the wire and fuse down to that terminal. I have no clue as to what caused the failure.
I verified power through the ignition switch but was not sure which specific wire went to the coil and relay wire in the engine harness. Found it after lots of continuity checks in various parts of the under-hood and under-dash rats nests until I located it and traced it back to the circuit board. This was a very miserable and time consuming job. Many hours of uncomfortable troubleshooting and the such a simple fix. All is now well. Thanks to all who gave advice.
Tags
coil, harness, ignition, wiring
