January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree2Likes
  • 1 Post By G_Edmonds
  • 1 Post By Jerry Clayton
Old 03-05-2021, 05:27 AM
Lightingrod's Avatar
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
Default Rollbar-Cage
Anyone install a cage in their CR-II. I think I really should do one!
Any help or advice will be appreciated!
Al
Al
I want to do right, Just not right NOW!
Old 03-05-2021, 02:39 PM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
If there was a drag strip within 100 miles of me, I’d like to.
I've spent most of my money on cars and women. The rest I wasted.
Old 03-05-2021, 04:03 PM
I reinforce the fake roll bar but it doesn't have the 3rd bar, just the U.
I was well over 130 a couple of days ago. Nothing crazy but the front felt kind of light? It could have been a cross-wind or just the road. I have been that fast before and didn't notice it! What kind of HP you getting out of that 408?
Al
Al
Old 03-05-2021, 06:25 PM
G_Edmonds's Avatar
Not sure. As a 6.0 with everything else the same, it dynoed 530 flywheel. Never tested it with the stroker kit.
Lightingrod likes this.
Old 03-05-2021, 09:03 PM
twobjshelbys's Avatar
Mine too, about the same speed, maybe a little more. Enough so that I didn't try to push it higher even though there was more than enough go to do so.
Tony
CSX4005LA
Old 03-07-2021, 05:55 AM
t walgamuth's Avatar
I believe you will begin feeling the front being pushed up by air along about 110 mph. I do in mine and did in my Miata as well.
Old 03-15-2021, 10:39 AM
I've had mine to a little over 140 mph but that was with an iron block SBC, it felt good and solid! I've had the current setup (LS3) over 120 mph a number of times and it seemed OK but not as good as when the front-end was heaver! It's also sitting a bit higher but it's hard to judge how much because I also changed the wheels and went to a little bigger tire at the same time!
Al
Old 03-16-2021, 08:43 AM
Jerry Clayton's Avatar
a BRICK WILL BECOME AIRBORNE AT AROUND 140----------
Old 03-16-2021, 01:46 PM
I bought the QA 1 suspension kit from Classic Roadsters II just before they went under, 2006 I think? Any idea of the spec's?
https://www.qa1.net/search/results/a...d34cdcc4e98599
Al
