Like Tree2Likes
  • 1 Post By Alfa02
  • 1 Post By 74proii
Old 08-01-2021, 03:47 PM
440.mustang's Avatar
Cobra Make, Engine: Classic roadsters 1991
Default Tires and wheels
What are the widest tires you can get on the classic roadster 1992, what is the best tires to run, prefer something sticky, 15" 16" or 17"
Old 08-02-2021, 10:55 AM
17 inch rims has the best selection of tires. From road racing to drag radial tires came in large selection. You can even go 18 inch rims with the same or larger selection of tires. It did pends on what you want to do with the car.
Old 08-02-2021, 07:16 PM
Alfa02's Avatar
Gold Star Contributor
I know quite a few CR & CR II have 15x10.5 rears. I went with 15x8 front & rears since I built mine as a 427Street (Rocket Sunbrust), with 3/4" offset in the rears. I'm sure other people will chime in with what offsets you will need for 15x10.5" Never went to 17/18" wanted the stock tire/wheel look, but yes there are a lot more tire/wheel combo's in 17/18". Good Luck, Cheers TommyRot.
440.mustang likes this.
Old 08-02-2021, 09:03 PM
Vintage wheels under their "Cobra Wheels" section shows the 15's and the offsets. Do a search here on the threads, there are several threads with all sizes. Remember the bigger the rim, the less the sidewall, thus harsher ride.
https://vintagewheelsus.com/index.ph...ex&cPath=59_77
Old 08-11-2021, 09:55 AM
I'm a pretty aggressive driver, I've been known to turn right to go left, this thing will probably be on the track at Nelson ledges and mid ohio, just want the best tires for traction, not really looking for a 70,000 mile tire,
Old 08-11-2021, 06:06 PM
Cobra Make, Engine: FF5 347 stroker
Go 17 in rim and select tire. No further discussion is necessary.
Old 08-12-2021, 12:09 PM
Thanks, that explains all I asked
