Like Tree2Likes
  • 1 Post By sunman
  • 1 Post By sunman
Old 08-18-2021, 09:06 PM
440.mustang's Avatar
Cobra Make, Engine: Classic roadsters 1991
Default Windshield wiper motor wiring
I wired up the windshield wiper motor and had a melt down, I bought a replacement piece for the park and high low connector, does anyone have a pic of where the wires are supposed to be,
Old 08-19-2021, 10:44 AM
cycleguy55's Avatar
Did you have the melt down, or was the melt down on the wiper motor or plug?
Does this help?
Brian
Old 08-19-2021, 02:46 PM
I'm trying to post a pic,
Old 08-19-2021, 07:28 PM
Wiring
Old 08-19-2021, 09:20 PM
sunman's Avatar
The top photo black is motor ground and red and yellow are high and low speed
Ground is the top spade and the two vertical spades are high and low
Put the red on top, yellow on bottom, I just think that red would be hi check that
The bottom photo is Classic wire harness spades
This is on page 6-7 in the manual
Top horizontal says “ground- remove from terminal and connect to chassis ground #190”
Top right vertical- constant power from ignition #123
Bottom right- park circuit- connect to low speed terminal #149
Top left vertical- hi speed wiper power #148
Bottom left- lo speed wiper power #149
#123,#148,#149 are in the Chevy steering column pigtail harness #1002320 page 3-74 in manual
Switch is in turn signal lever if you have Chevette, wire accordingly if not
Party On
Wyatt
Chaney Shores Studio
Old 08-20-2021, 07:00 AM
Thanks, I removed park switch and numbered location, but some how numbers disapeared, didn't want to burn it up again, but I think it was wired wrong when I got it, , I didn't find it in manual, thanks, now I can find it,
Old 09-05-2021, 09:04 PM
sunman's Avatar
Check out Wiper Motor thread 04-19-2004 for more info
It’s page 58 CR threads
440.mustang likes this.
Old 09-06-2021, 07:23 AM
That makes it much better, I sent this one to paint, I'll be starting the second cobra soon, that's the one I need the cowl hoop for,
Old 09-06-2021, 07:46 AM
sunman's Avatar
I finally have the body coming off and will get some hoop size info soon
Happy Labor Day
Union Made Holiday
Party On
