Old 08-28-2022, 10:27 AM
Hapnyny's Avatar
Default Replace lower rear control arms.
Any suggestion on a replacement for the rear lower control arms. I would like an adjustable option.
Thanks
Old 08-28-2022, 07:40 PM
fordsrule@msn.com's Avatar
Cobra Make, Engine: 427 Classic Roadster-347, AOD
Default Rear lower control arms
As far as I know they are custom length
Life is short enjoy it as soon as you can or it may be to late !!!
Old 08-29-2022, 04:48 AM
Sycraft's Avatar
Cobra Make, Engine: ford 302
I looked into it, but was cost and use prohibitive. The sway bar mounts to the lower arms, so that creates an additional challenge when building a heim jointed lower arm. Better off boxing off original arms and cutting off spring mount as others have done. Replace the bushings with poly (I did). creates a solid rear tracking. Many use the upper fox body adjustable links for the 8.8 diff to set pinion angle and such, mine have speherical bearings to minimize axle roll and movement.
