Like Tree1Likes
  • 1 Post By Chicagowil
Old 02-02-2023, 06:32 PM
Hapnyny's Avatar
Default Mustang II Forged Front Spindle, available in stock or 2" drop front spindles.
What do you recommend for an upgraded spindle and should I go with a 2 inch drop? I have QA1 Coil-Over for the Cobra with standard Heidts upper and lower tubular control arms?
Old 02-02-2023, 07:27 PM
Sycraft's Avatar
Cobra Make, Engine: ford 302
I think a 2" drop will be too much, adjust with the coilovers
Old 02-03-2023, 07:14 AM
Chicagowil's Avatar
Look at the front wheel well opening of your car & imagine the tire set up into the opening 2 inches deeper. It would be too much. Plus, the oil pans would be 2" closer to the ground. I have a Canton Road race oil pan, which is a lower profile, and it still hangs below the frame rails now.
markantioch likes this.
Old 02-04-2023, 07:54 AM
joyridin''s Avatar
You are going to be cranking the shocks up to keep it off the ground, and then it is going to ride like a tractor.
Use the standard and adjust spring pressure to lower it. It will ride nicer and handle better.
