Like Tree3Likes
  • 1 Post By HighPlainsDrifter
  • 2 Post By MasterAnubis
Old 07-26-2023, 10:14 PM
Default bake distribution block suggestions
Hello all,
Into my build, its a never stared CRII kit. I'm running a 302/5.0 with an 8.8 from a 91 fox, changed to 5 lug axles and sn95 calipers in the rear with gm single piston calipers on a mustang II front end from Heidts. I'm using tilton pedals with the dual brake reservoir and bias bar adjustment, so I don't think I need a proportioning valve. But I do think I need a brake distribution block. any suggestions on what to use?
Old 07-27-2023, 05:04 AM
Tommy's Avatar
If you are speaking of the T-blocks where the brake lines split for the front wheels and the rear wheels, it will depend on the fittings on the lines running to and from them. Summit Racing has a good selection if you know the fitting sizes. If you are asking what size fittings they are, I don't know.
Tommy
Previously owned EM Cobra
Old 07-27-2023, 11:54 AM
HighPlainsDrifter's Avatar
Default rear brakes
Hi,
you need an inline proportioning valve to the rear brakes and take out 40% pressure to rear brakes as they will lock up sooner than front . Speedway sells them.
Perry.
eschaider likes this.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 07-27-2023, 04:07 PM
MasterAnubis's Avatar
I think I'm on the same page as Tommy. You would only need a tee for the front and a tee for the back. Keep the front and rear separate.
Generally, a "distribution block" can include a proportioning pressure valve and a shuttle for a "brake" warning light. With dual masters, proper MS sizes and a balance bar you should be able to work with what you have.
Shawn
Tempe, AZ, USA
Old 07-27-2023, 07:25 PM
Tommy's Avatar
The OP said:
I agree. No proportioning valve is needed.
Tommy
Old 07-28-2023, 07:27 AM
but the balance bar should remove the need for a proportioning valve, no?
Old 07-28-2023, 02:17 PM
cycleguy55's Avatar
You don't need a distribution block for proper functioning of the braking system, as the balance bar will take care of that.
OTOH, you'll still need one to satisfy inspectors if your jurisdiction requires a functional brake system warning lamp.
Brian
Old 07-30-2023, 10:07 AM
Yes, provided that the master cylinders are sized right for your brake packages.
Tommy and eschaider like this.
Shawn
Tempe, AZ, USA
