Old 10-06-2024, 02:11 PM
Hapnyny's Avatar
Default Recommend 18 wheel
Hi CS Folks,
I built a 91 CR and have been going to road races with it. Front tubular control arms with double adjustable QA1’s. The rear is a Curry F9 with 355 gears. I picked up a pair of QA1 lower control arms for a fox body and cut them down to size, the uppers are also QA1’s. Thinking about changing from a four link to a three link? The rims? Looking to go with an 18 inch for only track, any suggestions?
Old 10-13-2024, 08:46 AM
Cobra Make, Engine: Classic Roadsters, 347 stroker
the 3 link is far superior. It provides a better ride, better cornering and no (not as much) surprises when cornering.
The 4 link can cause sudden and unexpected rear end swap. Many here with the 4 link have been in the situation where the rear just snaps and rotates out. Good only for drag racing.
Do a search on the subject and you will get allot of info.
Or so what only a couple people have done with a CR, but in an IRS rear end. Lost of work.
My four link with heim ends on the upper and urethane on the lowers will suit my application. I am still building mine.
