05-04-2002, 08:49 AM
Ont
Cobra Make, Engine: Classic Roadster with 427 center oiler
Radiator scoop (upper and lower)
Does anyone know where I can get the upper and lower radiator scoops made out of aluminum. (not the engine oil cooler shroud/scoop). I am referring to the two pieces of fiberglass located in the nose. If I remember correctly, the upper piece was already installed in the nose when I received the body. I had to install the lower piece.
I had a slight run in with a concrete curb and cracked the lower radiator scoop piece and the body below it. I can repair it and repaint, but I have always wanted to replace it with aluminum and now would be a good time.
Thanks
Paul
