Old 07-22-2002, 11:38 AM
petek's Avatar
Default Rear Coil Overs (hey Don)
Don,
Got the coil overs mounted to the rear in about a half hour. Quick, easy install. Two questions: the shock body is mounted to the lower mounting point, right?
Second question (in an attempt to save a tiny bit of time), where do you normally set the coil over (measurement from the bottom of the threads to the adjusting "nut").
THANKS!!!!
Pete K.
Who is John Galt?
Old 07-22-2002, 02:51 PM
dscott's Avatar
Pete, Yes the shock body mounts to the lower bracket. I usually set them about 2" from the bottom for a starting point. Glad everything went ok with the install.
Don
Old 07-22-2002, 03:00 PM
petek's Avatar
Thanks Don!
Pete K.
Who is John Galt?
