Old 08-14-2002, 07:56 PM
Default Master Cylinder help
DV or Don, When you build a car with manual brakes, what master cylinder do you use? I have searched the Napa catalog for master cylinders that come with the attached rod that will attach to the classic pedal assembly and come close to a 1" bore and dual large reserivors. So far I have stuck out. I guess I could go to a salvage yard an search around for the connecting rod then use any master clyinder with 1" bore and large capacity. My Napa guy tells me the corvette mc doesn't come with the conecting rod. If so, where do pick yours up at. With a manual setup, it appears the mc rod is about 5" long with the circular end piece. Thanks, Chuck
Old 08-15-2002, 06:25 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
I don't know of any manual master with the sizes you want. Everything I do is power. You'll have to search.
Don
