Old 09-22-2002, 11:54 PM
Post Over Flow Tank Question?
Where is the best place..and What is the best over flow tank to use? Running a 302 HO....with everything else that is CRL.
Thanks.
Snake.
Old 09-23-2002, 07:13 AM
dscott's Avatar
Snake, I've used several different types. The one I like the best is a billet tank from Jegs. It mounts vertical and I usually mount it on the fender liner close to the upper radiator hose.
Don
Old 09-23-2002, 09:02 PM
Post Dscott
Hey Don! Do you have a picture of one mounted? Which size do you use? 13", 15", 17".
Snake.
Old 09-24-2002, 06:43 AM
dscott's Avatar
Snake, sorry no pictures. I use the small one.
Don
Old 09-25-2002, 02:56 PM
Used a Track Auto import size coolant overflow kit. ~$15. Plastic bottle on driver side inner engine compartment well near rad. Water level raises and lowers about 1/2 quart between hot and cold. Not particularly "Trick" looking, but keeps coolant off garage floor, and inside radiator.
