Old 09-27-2002, 02:19 PM
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default Master Cylinder question
My buddiy is stripping out a 1984 1/2 Mustang.....
Will his Brake booster and Master Cylinder work with the Classic Roadster pedal assembly?
Old 09-27-2002, 03:17 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
It may work but I've never tried it. I just had the salvage yard pull one for me so I'll check it out and see if it fits. I'll let you know.
Don
Old 10-01-2002, 03:54 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Probably a good question that needs to be mocked up to see if it will fit, and work. A lot of MII stuff is getting harder, and harder to find, and a lot of late Mustang ('79 - up) fits with little or no modification. Late steering rack is a good example.
This is conjecture, but it would seem that IF the power booster fits, it would work. The OEM master cylinder would probably work with an 11" rotor front disk, and OEM drum brake rear. If converting to disks, you'll need the corresponding master cylinder that matches the rear disks used. Mine were '87 - '89 T-bird Turbo Coupe from the SVO rear disk brake conversion kit M-2300-C. Others are using Explorer rear disks, so you'd need the Explorer master cylinder.
Old 10-02-2002, 06:54 AM
dscott's Avatar
I tried the pedal set from a newer Mustang GT with the old Mustang II booster and the bolt pattern is different. It looks like the pedal set on the Cobra would need to be modified to fit the newer style booster. Shouldn't be a big deal though, just redrilling. I don't have a newer booster here so I don't know about the rod to the pedal yet. I'll keep working on it.
Don
Old 10-03-2002, 07:24 PM
A 1984 Power Booster will work
Old 10-03-2002, 08:07 PM
Cobra Make, Engine: Custom built Excalibur 351C
Default GN Power Master!
I'd recommend the GN Powermaster...Try it - You'll like it!
