Old 11-21-2002, 03:31 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Default Oil Heater/Cooler????
I have a Griffin aluminum radiator in my CR with 408W stroker. It is set up for an automatic in that it has the trans oil cooler on the passenger side.
Now, would it make sense to run engine oil through this "cooler" to heat it faster (less dist. and cam gear wear) and cool it when running hard (coolant runs 185*-195* at the hottest)
I've read that keeping mineral oil below 230* is good and thought this set-up might accomplish that easily without using an external oil cooler (some keep oil too cool)??? It may be that the additional oil heat would cause the engine to run hotter??
Comments & Ideas??
Thanks,
Jack???
